Very late into the 1964 model year, Chevrolet advised dealers of a change in carburetors earlier on the 1964 Corvettes. The date given of 11/26/63 was at the Carter carburetor plant. By the date of 11/26/63, almost 6,000 1964 Corvettes had left the St. Louis plant with the first design AFB carburetors.
Subject: Recalibration of Carter AFB Carburetors
Model and Year: 1964 800 & 1000 Series with 327" Engines
Source: Chevrolet Central Office Technical Service Bulletin
Bulletin No: DR #674
Section: VIm
Date: May 28, 1964
To minimize hesitation on acceleration and improve overall engine performance, the Carter AFB Carburetor used on 800 and 1000 Series vehicles with 327" engines was re-calibrated effective at the source approximately November 26, 1963. Carburetors incorporating the latest calibration may be identified by the following numbers which are stamped on the metal identification tag.
3720SA - Units with Automatic Transmissions
3721SA - Units with Manual Transmissions
If hesitation on acceleration is encountered on early production vehicles, the carburetor should be rebuilt using the parts listed on Page 2 of this bulletin.
VEHICLES WITH POWERGLIDE TRANSMISSIONS | ||
PART NUMBER | QUANTITY | DESCRIPTION |
3862088 | 1 | Primary Cluster (choke side) |
3862089 | 1 | Primary Cluster (pump side) |
7009575 | 2 | Primary Metering Jet |
1460475 | 2 | Secondary Metering Jet |
VEHICLES WITH MANUAL TRANSMISSIONS | ||
3862090 | 1 | Primary Cluster (choke side) |
3862091 | 1 | Primary Cluster (pump side) |
3821716 | 2 | Metering Rod |
Article ID: 128
Created: July 6, 2014
Last Updated: July 6, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-recalibration-of-carter-afb-carburetors-128.html
