C7 Corvette: Service Information: Transmission Control Lever Knob Replacement
C7 Corvette Transmission Control Lever Knob Replacement
Removal Procedure
![C7 Corvette Transmission Control Lever Knob Replacement C7 Corvette Transmission Control Lever Knob Replacement](/tech/knowledgebase/images/tech/3339735.gif)
- Carefully remove the shift control knob trim ring (1) by lifting upward and turning 1/4 turn counter-clockwise and pulling downward.
- Remove the shift control knob retaining fastener (2).
- Remove the shift control knob (3).
- Installation Procedure
- Clean the stub shaft and fastener (2) threads prior to reinstalling the shift knob to remove residual threadlocker using a (recommended) tap and die set.
- Install the shift control knob (3) onto the shift control lever.
- Apply threadlocker to the shift knob fastener (2) and install the fastener.
Caution: Refer to Fastener Caution .
- Install the shift control knob retainer fastener (2) and tighten to 7 Y (62 lb in) .
- Install the shift control knob trim ring (1) and turn clockwise to lock into place.
Save
Article ID: 1294
Created: August 5, 2016
Last Updated: August 5, 2016
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/c7-corvette-service-information-transmission-control-lever-knob-replacement-1294.html
