Subject: | Clicking Noise from Front and/or Rear Wheels |
Models: | 2014-2017 Chevrolet Corvette |
2016-2017 Chevrolet Camaro | |
Attention: | This PI also applies to any of the above models that may be Export from North America vehicles. |
This PI has been revised to add the Camaro model and the 2017 Model Year. Please discard PI1498A.
Some customers may comment on a clicking noise emanating from either the front or rear wheels location. This condition may be more predominate at low speeds (10-20 mph or 16-32 km/h) during full wheel lock turns on dry clean pavement. The clicking noise is generally noted as approximately 1 to 4 clicks per wheel revolution.
This may be caused by interaction between the wheel mounting face and the wheel mounting surface on the brake rotor.
Important: Do NOT replace the wheels or brake rotors for this condition.
If you encounter a vehicle with the above concern, follow the procedure below.
Note: All cleaning must be done by hand. Do NOT use pneumatic or power tools.
Note: During the cleaning process, be sure to clean the rotor near the wheel pilot at the center of the rotor.
Important: Be sure wheels and rotors are thoroughly dry prior to installation.
Article ID: 1301
Created: August 25, 2016
Last Updated: August 25, 2016
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-clicking-noise-from-front-and-or-rear-wheels-aug-23-2016-1301.html
