Subject: | Door Rattle Noise from Outside of Vehicle During High Radio Volume or High Bass Levels |
Models: | 2014-2016 Chevrolet Corvette |
Attention: | This PI also applies to any of the above models that may be Export from North America vehicles. |
This PI has been revised to remove a breakpoint and add the 2015-2016 Model Years. Please discard PI1116.
Some customers may comment on hearing a driver or passenger front side door rattle noise during high radio volume or high bass levels. The noise is most commonly described as more evident from outside the vehicle rather than inside.
The cause of this condition may be voids in adhesive (1), leaving gaps between the inner door beam and the door skin.
The graphic above shows an example in which a tie strap (1) was passed through a 15-20 cm (6-8 in) length gap where the adhesive was missing towards the center of the door.
This can also occur in the front and/or rear area of the door beam; with the condition sometimes more evident in the front area (shown above) where the radio speaker is mounted.
Inspect the front side door beam and door skin gap for voids and add a bead of butyl ribbon sealer in those areas following the steps below:
Tip: Use of a trim stick, or equivalent tool, may help to work the sealer into the gap.
*We believe this source and their products to be reliable. There may be additional manufacturers of such products/materials. General Motors does not endorse, indicate any preference for, or assume any responsibility for the products or material from this firm or for any such items that may be available from other sources.
Part Number |
Description |
08611 |
3M Windo-Weld™ Ribbon Sealer |
Article ID: 1305
Created: September 15, 2016
Last Updated: September 15, 2016
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-pi1116a-door-rattle-noise-from-outside-of-vehicle-during-high-radio-volume-or-high-bass-levels-sep-14-2016-1305.html
