Condition: Certain 2016 model year Chevrolet Corvette vehicles, equipped with an 8 speed automatic transmission (RPO M5U) and an extra capacity cooling system (RPO V03), may have a condition in which the transmission oil cooler (TOC) lines come in contact with the body studs for the outer quarter panel reinforcement. Over time this contact may wear a hole through the line causing a fluid leak. It is possible that the leak may not be visible, but could lead to illumination of the malfunction indicator lamp, rough/irregular shifts, slipping, and, eventually, complete loss of propulsion.
Campaign Notices is attached below:
Article ID: 1322
Created: January 23, 2017
Last Updated: January 23, 2017
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-recall-16038-transmission-oil-cooler-line-in-contact-with-body-stud-1322.html
