Subject: | Tire Hop / Tire Chatter During Tight Turns at Parking Lot Speeds |
Models: | 2014 - 2017 Chevrolet Corvette, Corvette Z51 |
2015 - 2017 Chevrolet Corvette Z06 | |
Attention: | This Bulletin also applies to any of the above models that may be Export from North America vehicles. |
This Bulletin has been revised to add the 2017 Model Year. Please discard Corporate Bulletin Number 14-03-10-001B.
Customers may comment about a front end or suspension noise when backing or driving forward at low speed in a very tight left or right turn (such as in a parking lot or driveway). The condition is made worse in cooler temperatures. This has been referred to as tire hop, crow hop, tire pop and has been confused with rear differential chatter. There have been several bulletins, videos and training pieces published in attempt to describe the noise and explain that the condition is considered normal. (For dealers in the U.S., see January 14, Emerging Issues “Corvette Tire Hop Story”). This concern is not new for the Corvette, it has been raised by customers of older Corvettes and other vehicles with a wide stance and wide tires.
The Corvette Stingray may have more noticeable tire chatter than previous years due to several factors explained below:
Ackermann steering geometry is shown in the diagram below. On a car with perfect Ackermann, the inside tire angle (Si) and outside tire angle (So) follow the same arc. On a Corvette Stingray, at large steering angles, they do not follow the same arc.
Why Do The Tires Not Follow the Same Arc?
While a customer may find the noise troubling and/or annoying, the car is operating as designed. Tire hop was more common on the previous generation Corvette Z06, ZR1 and Grand Sport models. It is more noticeable on the Corvette Stingray because much of the performance from those previous up-level models has been designed into the standard Stingray. Aside from the exceptional design and appearance, the outstanding performance, and handling is one of the reasons customers choose to purchase the Corvette Stingray. To achieve this type of performance, some tire hop is inevitable.
Article ID: 1325
Created: March 7, 2017
Last Updated: March 7, 2017
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-14-03-10-001c-tire-hop-tire-chatter-during-tight-turns-at-parking-lot-speeds-1325.html
