Subject: | Repeated Radio/display Resets, Volume Control Inoperative, Waiting for Update Media Message, Voice Command For Calling Bluetooth Phone Contacts Inoperative, Service Rear Vision System Message, Radio Turns On Unwanted At Startup, and/or Navigation Radio Destination State Defaults To WV |
Attention: | This bulletin contains a unique labor code specifically for this reprogramming event. Please use the labor code listed in this bulletin when submitting the claim. |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Buick |
Encore Envision LaCrosse Regal |
2016 |
2017 |
All |
All |
Cadillac |
ATS CT6 CTS ELR Escalade Models XTS |
2016 |
2017 |
All |
All |
Cadillac |
XT5 |
2017 |
2017 |
All |
All |
Chevrolet |
Camaro Colorado Corvette Impala Malibu Silverado Suburban Tahoe |
2016 |
2017 |
All |
All |
GMC |
Canyon Sierra Yukon Models |
2016 |
2017 |
All |
All |
GMC |
Acadia (VIN N) |
2017 |
2017 |
All |
All |
Involved Region or Country |
North America and N.A. Export Regions |
Additional Options (RPO) |
Equipped with IO5 and IO6 |
Condition |
Some customers may comment on one or more of the following conditions: ![]()
Note: This software update also includes CarPlay and Android Auto Improvements. |
Cause |
This may be due to a software anomaly. |
If you encounter a vehicle with the above concern, check the HMI build version.
Verify the HMI build version by completing the following:
To verify the HMI build version, on the radio, push the following button combination together (refer to chart below), then select HMI from the onboard development screen.
Buick |
Power+Menu+Home - release Home first after Development screen is displayed |
Cadillac |
Home+Volume down or Home+Mute |
Chevrolet |
Power+Home+Back or Power+Home+Menu |
GMC |
Power+Menu+Home |
Once in Development Screen press HMI and document the Buildversion-Custverstring
If the software is one of the following, reprogram the Human Machine Interface Control Module. Refer to Human Machine Interface Control Module Programming and Setup in SI.
If the software is one of the following, refer to SI for further diagnosis.
To program an existing control module, perform the following procedure:
Note: The vehicle must remain in PARK during the programming procedure.
Important: A 8GB USB will be needed for this update.
Note: If issues loading to USB, verify USB format is FAT32.
Note: If there are no files available for USB transfer via SPS, proceed to step 10.
Note: Software currently loaded on the USB Drive will be verified and if files are incorrect they will be deleted and correct files will be loaded. If files residing on the USB Drive are correct for the vehicle being serviced, the Techline terminal will not delete those files and allow the drive to be re-used.
Note: The HMI will not allow the installation of the same software version via USB. If the same software is detected the installation process will not start.
Important: Before installing USB, verify that no other USBs are installed in the USB ports.
Labor Operation |
Description |
Labor Time |
9800003 |
2016-2017 Service Reprogramming for HMI IO5 or IO6 |
0.6 hr |
Version |
2 |
Modified |
March 3, 2017 – Added Buick Encore and Envision models and removed fixing HVAC control function not showing on main display fix. |
Article ID: 1326
Created: March 14, 2017
Last Updated: March 14, 2017
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-17-na-025-repeated-radio-display-resets-volume-control-inoperative-waiting-for-update-media-message-voice-command-for-calling-bluetooth-phone-contacts-inoperative-service-rear-vision-system-message-radi-1326.html
