Subject: | Brake Squeal or Squeak Noise Intermittently on Initial Brake Applies |
This Bulletin replaces PI1496C and PI0917F. Please discard PI1496C and PI0917F.
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Buick |
Regal GS |
2013 |
2019 |
All |
All |
Cadillac |
ATS XTS |
2013 |
2019 |
All |
All |
Cadillac |
CTS (VIN A) |
2014 |
2019 |
All |
All |
Cadillac |
ATS-V, CTS-V, CT6 |
2016 |
2019 |
All |
All |
Chevrolet |
Corvette |
2014 |
2020 |
All |
All |
Chevrolet |
SS |
2014 |
2017 |
All |
All |
Involved Region or Country |
North America and N.A. Export Regions |
Condition |
Some customers may comment on a squeal or squeak noise from the front brakes. This condition normally only occurs on initial brake applications after the vehicle has sat for an extended time. The condition occurs typically under light braking, in speeds under 16 km/h (10 mph). After 1-6 brake applies, or after braking at higher speeds, the noise no longer occurs. This condition may occur more often in high humidity conditions. |
Correction |
Apply a coat of copper paste to completely cover the pad backing plate abutments on each end. |
Description |
Part Number |
Qty |
Lubricant |
19303310 (In Canada, use 19303311) |
3 |
For vehicles repaired under the Bumper-to-Bumper coverage (Canada Base Warranty coverage), use the following labor operation. Reference the Applicable Warranties section of Investigate Vehicle History (IVH) for coverage information.
Labor Operation |
Description |
Labor Time |
2480038* |
Cleaning and Reapplying Lubricant to Front Disc Brake Pads |
0.6 hr |
Add |
Cleaning and Reapplying Lubricant to Rear Disc Brake Pads |
0.4 hr |
*This is a unique Labor Operation for Bulletin use only. |
Important: The use of wheel cleaners or power washers directly pointed at the brake caliper may wash the copper paste off of the brake pads. It may be necessary to apply the copper paste again if the lubricant is washed away. The copper paste should be applied whenever the brake pads are removed or replaced.
Important: (Chevrolet SS Models Only) Do not apply the copper paste to the back of the backing plate.
Apply a coat of copper paste to completely cover the pad backing plate abutments on each end. The paste should not extend onto the friction material. Follow the instructions listed below.
Buick Regal
(1) | Abutment Area |
(1) | Cleaned Abutment Area |
(2) | Correct Amount of Copper Paste |
(3) | Incorrect Amount of Copper Paste |
Note: Avoid a light apply of the paste as illustrated above.
Cadillac Models and Chevrolet Models
Note: Ensure that the ends of the brake pads have enough copper paste applied, if not, could result of the noise condition returning.
Note: DO NOT replace brake pads for this condition.
Important: DO NOT remove the silencers (1) on the pads.
Important: Always replace brake pads with Brembo GM OEM pads (2). Aftermarket pads could result in the braking performance changing in many ways.
Version |
5 |
Modified |
March 6, 2017 – Added the Cadillac CT6 model. March 17, 2017 – Removed an Important statement from Service Procedure. November 30, 2018 – Added the 2018 and 2019 Model Years. August 11, 2020 – Added the 2020 Corvette Model, updated the Involved Region or Country section, added an Export region statement to the Parts Information and relocated the Parts Information and Warranty Information sections. |
Article ID: 1327
Created: March 14, 2017
Last Updated: December 28, 2020
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2020-corvette-service-bulletin-17-na-040-brake-squeal-or-squeak-noise-intermittently-on-initial-brake-applies-august-11-2020-1327.html
