Subject: | Ticking Rattle Or Buzz Noise Heard The Best In The Passenger Compartment |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Cadillac |
CTS-V |
2016 - 2017 |
All |
All |
6.2L LT4 |
All |
Cadillac |
Escalade |
2015-2017 |
All |
All |
6.2L L86 |
All |
Chevrolet |
Camaro |
2016-2017 |
All |
All |
6.2L LT1 LT4 |
All |
Chevrolet |
Corvette |
2015 - 2017 |
All |
All |
6.2L LT1 LT4 |
All |
Chevrolet |
Silverado |
2014-2017 |
All |
All |
4.3L 5.3L 6.2L L83 L86 LV3 |
All |
Chevrolet |
Suburban |
2015-2017 |
All |
All |
5.3L L83 |
All |
Chevrolet |
Tahoe |
2015-2017 |
All |
All |
5.3L L83 |
All |
GMC |
Sierra |
2014-2017 |
All |
All |
All |
GMC |
Yukon Modules |
2015-2017 |
All |
All |
5.3L 6.2L L83 L86 |
All |
Supersession Statement
This PI was superseded to update Recommendation/Instructions. Please discard PIP5395A.
A customer concern of rattle or ticking noise that is louder inside the vehicle than outside.
The noise may be picked up at the back of the left valve cover.
The noise may also sound like a lifter tick
This may also be called a fuel line buzz or ringing noise.
Listen to the fuel line connection at the left side of the engine.
If the noise is heard best at the fuel line (this sound will be real loud with a stethoscope).
The fuel feed line between the high pressure fuel pump and chassis fuel line could be the cause allowing high pressure pulsation back to the low side of the fuel system. There is not a good way to test the check valve, the line will need to be replaced.
On pickups and SUVs, a vibration in the fuel line at the fuel tank may also be observed.
Reevaluate the concern.
There are two different fuel line types that contain this check valve and vary by model.
The line above is the fuel feed pipe for Corvette, truck and SUV.
This line connects the chassis fuel line to the high pressure fuel pump.
These pictures above shows the chassis fuel feed pipe for the LT4 supercharged ZL1 Camaro.
On LT1 Camaro and LT4 CTS-V this line would have a jumper line with quick disconnects at both ends.
One end will connect to the chassis line and the other to the high pressure pump feed line.
Labor Operation |
Description |
Labor Time |
4026830 |
Fuel Feed Pipe Replacement |
Use Published Labor Operation Time |
Article ID: 1338
Created: March 21, 2017
Last Updated: March 21, 2017
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-z06-service-bulletin-pip5395b-ticking-rattle-or-buzz-noise-heard-the-best-in-the-passenger-compartment-mar-20-2017-1338.html
