Subject: | Extended Crank Cold With DI (Direct Injected) Engines |
Models: | 2016–2018 Chevrolet Camaro |
2016–2018 Cadillac CTS-V | |
2015-2018 Cadillac Escalade | |
2014 - 2018 Chevrolet Corvette | |
2014-2018 Chevrolet Silverado 1500 Suburban, Tahoe | |
2014-2018 GMC Sierra 1500 Yukon | |
with engines 4.3L, 5.3L, 6.2L RPO’s LV3, L83, L86, LT1, LT4 |
This PI was superseded to update Model Years. Please discard PIP5179B.
DI (Direct Injected) Engines with concerns of extended or long crank time during cold ambient airtemps
Direct Injection engines may have slightly longer cold crank times than that of port fuel engines.
Direct Injection systems run at higher pressures, and the mechanical pump on the engine must buildup the required pressure before the first injection event occurs.
The below are typical Direct Injection engine crank times on GASOLINE
Start up Coolant Temperature Crank Time
Above 10° C up to 1.5 sec
Between 10°c (50F) and (- 10°c 14F) up to 2.5 sec
Between (-10°c 14F) and (-20°c -4F) up to 3.5 sec
Between (-20°c -4F) and (-25°c -13F) up to 5 sec
Between (-25°c -13F) and (-30°c -22F) up to 7 sec
Below -30 deg. C -22F, the recommendation is to perform an assisted start (such as use of a blockheater).
Note: For ETHANOL fuel see #PIP5174: Extended Engine Crank Times When Using E85
Article ID: 1351
Created: April 6, 2017
Last Updated: April 3, 2018
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5179d-extended-crank-cold-with-di-direct-injected-engines-mar-27-2018-1351.html
