Subject: | Information For Servicing Fuel Injector Oil Ring Seal Replacement For Fuel Odor And/or Extended Cranking Condition |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Cadillac |
CTS-V |
2016-2017 |
All |
All |
6.2L LT4 |
All |
Cadillac |
Escalade |
2015-2017 |
All |
All |
6.2L L86 |
All |
Chevrolet |
Camaro |
2016-2017 |
All |
All |
6.2L LT1 LT4 |
All |
Chevrolet |
Corvette |
2014 - 2017 |
All |
All |
6.2L LT1 LT4 |
All |
Chevrolet |
Silverado 1500 |
2014-2017 |
All |
All |
4.3L LV3 5.3L L83 6.2L L86 |
All |
Chevrolet |
Suburban |
2015-2017 |
All |
All |
5.3L L83 |
All |
Chevrolet |
Tahoe |
2015-2017 |
All |
All |
5.3L L83 |
All |
GMC |
Sierra 1500 |
2015-2017 |
All |
All |
All |
GMC |
Yukon Models |
2015-2017 |
All |
All |
5.3L L83 6.2L L86 |
All |
Supersession Statement
This PI was superseded to update Repair information and Model Years. Please discard PIP5234B.
The dealer may encounter a concern where SI diagnostics indicates a fuel injector may need to be removed for a repair or replaced.
This could be due to a fuel odor and/or extended cranking condition.
Note: **** Tightening the nuts is not an approved procedure *****
If you cannot conclude if the leak is coming from one of the fuel feed pipes, start the engine and let idle for 5 minutes looking for source of leak. Refer to SI for further diagnostics.
If this concern is encountered use the O-ring seal listed below.
If an injector is being replaced be sure all the injectors are installed with new seals. (That includes the new injector)
The following Fuel injector PN’s require a new O ring before installation.
Important: It is required to replace the engine fuel feed intermediate pipes during any service repairs that required one or more of the pipes to be loosened or removed.
Important: If any damage occurred due to leaking fuel, be sure to replace as necessary. (i.e. Fuel Pump Insulator)
LV1-LV3-L83-L86-LT1 Seal Kit = 12668553 should be used for the following injector kits:
LV1-LV3-L83 Service Injector:
12656932 (Nominal Flow)
LT1/L86 Service Injectors:
12656931 – Nominal Flow
12660002 – Low Flow
12660003 – High Flow
LT4 Seal Kit = 12668554 should be used for the following injector kits:
LT4 Service Injectors:
12661029 – Nominal Flow
12661030 – Low Flow
12661031 – High Flow
The correction for this concern may be one of several repairs described above. For vehicles repaired under warranty, please use the appropriate warranty labor operation based on the actual cause and repair
Article ID: 1360
Created: May 2, 2017
Last Updated: May 2, 2017
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-service-bulletin-pip5234c-information-for-servicing-fuel-injector-oil-ring-seal-replacement-for-fuel-odor-and-or-extended-cranking-condition-1360.html
