Subject: | Information On Fuel Odor and/or Fuel Leaks from Underhood SIDI Pipes Between High Pressure Pump and Fuel Rails |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Cadillac |
CTS |
2016 |
2017 |
LT4 |
All |
Escalade |
2015 |
2017 |
L83, L86, |
All |
Escalade ESV |
2015 |
2017 |
L83, L86, |
All |
Chevrolet |
Camaro |
2016 |
2017 |
LT1, LT4 |
All |
Silverado 1500 |
2014 |
2014 |
LV1, LV3, L83, L86 |
All |
Corvette |
2015 |
2017 |
LT1, LT4 |
All |
Suburban 1500 |
2015 |
2017 |
L83, L86, |
All |
Tahoe |
2015 |
2017 |
L83, L86, |
All |
GMC |
Sierra 1500 |
2014 |
2014 |
All |
Yukon |
2015 |
2017 |
L83, L86, |
All |
Yukon XL |
2015 |
2017 |
L83, L86, |
All |
Involved Region or Country |
North America and N. A. Export Regions |
Condition |
Some customers may comment on one or more of the following conditions:
The technician may find fuel leaking around the bellhousing or VLOM. Note: The conditions listed may occur with or without the Malfunction Indicator Lamp (MIL) illuminating. |
Important: It is required to replace the engine fuel feed intermediate pipes during any service repairs that required one or more of the pipes to be loosened or removed. |
Cause |
This condition may be caused by the result of a fuel leak at one of the high pressure fuel rail pipe connections that was installed incorrectly during service of another engine component, that required the fuel system to be opened. (i.e. fuel rail, lifter, head gasket, High pressure pump, injector, etc.) |
Correction |
Important: If any damage occurred due to leaking fuel, be sure to replace as necessary. (i.e. Fuel Pump Insulator) ![]() If you encounter a vehicle with the above concern, perform the following steps:
Note: **** Tightening the nuts is not an approved procedure *****
If you cannot conclude if the leak is coming from one of the fuel feed pipes, start the engine and let idle for 5 minutes looking for source of leak. Refer to SI for further diagnostics. |
Refer to the Electronic Parts Catalog (EPC) to determine the proper part numbers required for the Fuel Feed Pipe and the Fuel Feed Intermediate Pipes, if replacement is required.
Refer to Fuel Feed Pipe Replacement in SI.
Refer to Fuel Feed Intermediate Pipe Replacement - Position 1 in SI.
Refer to Fuel Feed Intermediate Pipe Replacement - Position 2 in SI.
Version |
2 |
Modified |
July 11, 2017 - Updated the Models, Correction and Parts Information sections. |
Article ID: 1375
Created: July 12, 2017
Last Updated: July 12, 2017
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-15-na-002-information-on-fuel-odor-and-or-fuel-leaks-from-underhood-sidi-pipes-between-high-pressure-pump-and-fuel-rails-1375.html
