Subject: | 17287 Frontal Airbag and Pretensioner Non Deploy |
Models: | 2014–2017 Buick Encore |
2014–2016 Buick LaCrosse | |
2015–2016 Cadillac Escalade, Escalade ESV | |
2014–2016 Chevrolet Caprice | |
2014 – 2017 Chevrolet Corvette | |
2015–2016 Chevrolet Silverado HD | |
2014–2017 Chevrolet Silverado LD | |
2014–2016 Chevrolet Spark EV, SS | |
2015–2017 Chevrolet Suburban, Tahoe | |
2015–2016 Chevrolet Trax | |
2015–2017 GMC Sierra HD, Yukon, Yukon XL | |
2014–2017 GMC Sierra LD |
Reference Number: N172105680 |
Release Date: July 2017 |
Revision: 00 |
Attention: |
It is a violation of Federal law for a dealer to deliver a new motor vehicle or any new or used item of motor vehicle equipment (including a tire) covered by this notification under a sale or lease until the defect or noncompliance is remedied. All involved vehicles that are in dealer inventory must be held and not delivered to customers, dealer traded, or used for demonstration purposes until the repair contained in this bulletin has been performed on the vehicle. |
Make |
Model |
Model Year |
RPO |
Description |
From |
To |
Buick |
Encore |
2014 |
2017 |
LaCrosse |
2014 |
2016 |
Cadillac |
Escalade |
2015 |
2016 |
Escalade ESV |
Chevrolet |
Caprice |
2014 |
2016 |
Corvette |
2014 |
2017 |
Silverado HD |
2015 |
2016 |
Silverado LD |
2014 |
2017 |
Spark EV |
2014 |
2016 |
SS |
Suburban |
2015 |
2017 |
Tahoe |
Trax |
2015 |
2016 |
GMC |
Sierra HD |
2015 |
2017 |
Sierra LD |
2014 |
2017 |
Yukon |
2015 |
2017 |
Yukon XL |
Involved vehicles are marked “open” on the Investigate Vehicle History screen in GM Global Warranty Management system. This site should always be checked to confirm vehicle involvement prior to beginning any required inspections and/or repairs.
Condition |
This condition relates to General Motors’ prior recall number 16V-651 (16007). In receiving service for the condition covered by this recall, some vehicles may not have received the new software for the sensing and diagnostic module (SDM) that is necessary to remedy the recall condition. General Motors has decided that a defect which relates to motor vehicle safety exists in these vehicles. As GM stated in its Part 573 report filed in connection with recall number 16V-651 (16007), the original SDM software in these vehicles, which controls airbag and pretensioner deployment, contains a defect which may prevent the deployment of frontal airbags and pretensioners in certain rare circumstances. If the frontal airbags and seatbelt pretensioners do not deploy when required, there is an increased risk of injury to occupants in a crash. |
Correction |
Dealers will reprogram the SDM with new software that eliminates this defect using a revised service procedure. In vehicles with any previous deployment events recorded in the SDM, the dealers will replace the existing SDM with a new SDM containing the latest software. |
Note: If a replacement is required, use the VIN and the GM Electronic Parts Catalog (EPC) to determine which SDM to order. It is estimated that only 1% of involved vehicles will require SDM replacement. Due to limited initial parts availability, dealers are encouraged not to order recall parts for use as shelf stock.
Labor Operation |
Description |
Labor Time |
Trans. Type |
Net Item |
* 9102923 |
Inflatable Restraint Sensing and Diagnostic Module Reprogramming with SPS |
0.3 |
ZFAT |
N/A |
* 9102924 |
Replace Airbag Sensing and Diagnostic Module (Includes Programming) |
ZFAT |
N/A |
9103292 |
Customer Reimbursement Approved - For USA and Canada dealers only - For Export dealers only |
N/A 0.2 |
ZFAT |
9103293 |
Customer Reimbursement Denied – For USA dealers only |
N/A |
ZFAT |
Note: To avoid having to “H” route the customer reimbursement transaction for approval, it must be submitted prior to the repair transaction.
* To avoid warranty transaction rejections, the SPS Warranty Claim Code must be entered and Programming Result Screenshot attached to the GWM system when submitting this transaction.
** Refer to Airbag Sensing and Diagnostic Module Replacement in the LTG for the appropriate labor time on the make and model being repaired.
*** For USA and Canada: Submit the dollar amount reimbursed to the customer in Net/Reimbursement. Submit $20.00 administrative allowance in Net/Admin Allowance.
For Export: Submit the dollar amount reimbursed to the customer in Net/Reimbursement.
**** Submit $10.00 administrative allowance in Net/Admin Allowance.
Note: (FOR US DEALERS ONLY)
Based on the large volume of involved vehicles in dealer inventory, please review section 3.2.9 of the GM Service Policies & Procedures Manual regarding Technician Identification and Accounting of Labor. This section states “For multiple vehicles requiring reprogramming, as well as service update bulletins and field actions involving inspections only (No parts replacement), the technician is not required to punch on/off time tickets by job card.”
Note: Carefully read and follow the instructions below.
Programming SDM
Note: If programming fails, before contacting TCSC, refer to the “Unable to Program SDM” section below to note the value of the parameter name “Software Module 1 Identifier” and “Software Module 2 Identifier”.
Pre-SPS Programming Tips
Important: The screen above should show all “PASS” or “SKIPPED” and/or PASS” if the programming event is successful. If ANY of the results show “FAILED”, proceed to “Unable to Program SDM” section.
Submit a screenshot of the “Programming Sequence (Programming Results)” including the VIN (lower right corner) in the screenshot as shown above along with the SPS Warranty Claim Code when submitting this transaction.
Important: To capture a screenshot:
Note: “Software Module 1 Identifier” and “Software Module 2 Identifier” provides deployment or near-deployment event information.
The US National Traffic and Motor Vehicle Safety Act provides that each vehicle that is subject to a recall of this type must be adequately repaired within a reasonable time after the customer has tendered it for repair. A failure to repair within sixty days after tender of a vehicle is prima facie evidence of failure to repair within a reasonable time. If the condition is not adequately repaired within a reasonable time, the customer may be entitled to an identical or reasonably equivalent vehicle at no charge or to a refund of the purchase price less a reasonable allowance for depreciation. To avoid having to provide these burdensome remedies, every effort must be made to promptly schedule an appointment with each customer and to repair their vehicle as soon as possible. In the recall notification letters, customers are told how to contact the US National Highway Traffic Safety Administration if the recall is not completed within a reasonable time.
All new, used, GM Certified Used, courtesy transportation vehicles, dealer shuttle vehicles, etc. in dealers’ possession and subject to this recall must be held and inspected/repaired per the service procedure of this bulletin before customers take possession of these vehicles. Involved vehicles must be held and not delivered to customers, dealer-traded, released to auction, used for demonstration, or any other purpose.
All GM Certified Used vehicles currently in the dealers’ inventory within the Certified Pre-Owned Inventory System (CPOIS) will be de-certified andmust be held and remedied per the service procedure in this bulletin. Upon submitting an accepted/paid warranty transaction in the Global Warranty Management (GWM) system, the vehicle can be re-certified for sale within the CPOIS system, or once again be used in the CTP program.
Dealers are to service all vehicles subject to this recall at no charge to customers, regardless of mileage, age of vehicle, or ownership, from this time forward.
Customers who have recently purchased vehicles sold from your vehicle inventory, and for which there is no customer information indicated on the dealer listing, are to be contacted by the dealer. Arrangements are to be made to make the required correction according to the instructions contained in this bulletin. Recall follow-up cards should not be used for this purpose, since the customer may not as yet have received the notification letter.
In summary, whenever a vehicle subject to this recall enters your vehicle inventory, or is in your dealership for service in the future, you must take the steps necessary to be sure the recall correction has been made before selling or releasing the vehicle.
For dealers with involved vehicles, a listing with involved vehicles has been prepared and will be provided to U.S. and Canadian dealers through the GM GlobalConnect Recall Reports, or sent directly to export dealers. The listing may contain customer names and addresses obtained from Motor Vehicle Registration Records. The use of such motor vehicle registration data for any purpose other than follow-up necessary to complete this recall is a violation of law in several states/provinces/countries. Accordingly, you are urged to limit the use of this report to the follow-up necessary to complete this recall.
Courtesy transportation is available for customers whose vehicles are involved in a product program and still within the warranty coverage period. See General Motors Service Policies and Procedures Manual, Sections 1.4 and 6.1.10, for courtesy transportation program details.
USA & Canada - General Motors will notify customers of this recall on their vehicle.
Export - Letters will be sent to known owners of record located within areas covered by the US National Traffic and Motor Vehicle Safety Act.
Customer requests for reimbursement of previously paid repairs to correct the condition described in this bulletin are to be submitted to the dealer prior to or by July 31, 2018. See General Motors Service Policies and Procedures Manual, Section 6.1.11 – Product Field Action Customer Reimbursement Procedure (USA & Canada) or local Policies and Procedures, for details.
Article ID: 1376
Created: July 12, 2017
Last Updated: July 12, 2017
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2017-corvette-product-safety-recall-frontal-airbag-and-pretensioner-non-deploy-jul-10-2017-1376.html
