Subject: | Stalling Shudder And/or Hard shifting Into 1st Gear Or Reverse Vibration On launch (With Excessive Crankshaft End Play) |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Cadillac |
CTS-V |
2015 - 2018 |
All |
All |
6.2L LT4 |
All |
Cadillac |
Escalade |
2015-2018 |
All |
All |
6.2L L86 |
All |
Chevrolet |
Camaro |
2016-2018 |
All |
All |
6.2L LT1 LT4 |
All |
Chevrolet |
Corvette |
2014 - 2018 |
All |
All |
6.2L LT1 LT4 |
All |
Chevrolet |
Silverado |
2014-2018 |
All |
All |
4.3L 5.3L 6.2L LV3 L83 L86 |
All |
Chevrolet |
Suburban |
2015-2018 |
All |
All |
5.3L L83 |
All |
Chevrolet |
Tahoe |
2015-2018 |
All |
All |
5.3L L83 |
All |
GMC |
Sierra |
2014-2018 |
All |
All |
All |
GMC |
Yukon Module |
2015-2018 |
All |
All |
5.3L 6.2L L83 L86 |
All |
Supersession Statement
This PI was superseded to update Models. Please discard PIP5248C.
Customers may have a Corvette that exhibits one of the following conditions:
Clunk when shifting into reverse or drive (automatic)
The crankshaft and or Thrust Bearing needs to be replaced, please use following information before considering a crankshaft replacement.
This concern could be caused by excessive crankshaft end play.
Check to determine if the crank shaft end play is within specification 0.0015–0.0086 in (0.040–0.220 mm). See eSI.
If end play is found to be out of specification, remove engine and inspect for possible Crankshaft thrust bearing and/or crankshaft for wear.
Note: If bearings and crankshaft look like components in attached picture, damage has not occurred.
Inspect thrust bearing for wear on one side and crankshaft on that “mating” surface.
If wear is evident (3 vertical channels worn off) replace connecting rod bearings, main bearings, thrust bearing and crankshaft.
Corvette OnlyFor this repair the oil tank with lines and oil cooler are both required to be replaced if equipped.
Note: Be sure to follow all SI documents for DSA replacement
Note: It is required on dry sump engines, the oil tank and lines should be replaced when replacing and/or repairing the engine.
Note: Also if equipped, the oil cooler is also required to be replaced.
If the customer prefers to KEEP the original numbers matching engine please call TAC for repair direction
For vehicles repaired under warranty use:
Labor Operation |
Description |
Labor Time |
4066750 |
Crankshaft Replacement |
Use Published Labor Operation Time |
Article ID: 1377
Created: August 16, 2017
Last Updated: August 16, 2017
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html
