Harsh shifting conditions and delayed garage shift engagements may be noticed on some 2017 Colorado, Canyon, Express, Savana; 2016-2017 ATS, CT6, CTS, Camaro; 2015 - 2017 Escalade, Silverado, Sierra, Yukon Denali, and Corvette models equipped with the 8L45 or 8L90 automatic transmission (RPOs M5N, M5T, M5U, M5X). (Fig. 12) The harsh shift conditions may be caused by one or more clutch fill times not completely learned in the Transmission Control Module (TCM).
Fig. 12
DTCs and Updated Calibrations
As a starting point for diagnosing all 8L45/8L90 transmission shift conditions, check for DTCs in all modules and address the causes for setting the DTCs. Also check for any available ECM/TCM calibration updates.
Refer to the following bulletins for additional information:
Test Drive with GDS2
A test drive of the vehicle should be completed in order to attempt to duplicate the concern. Use GDS2 to capture a session log of the event and bookmark when the shift concern is identified. Review the GDS2 session log to identify which shift(s) are occurring at each bookmark.
These bulletins are based on the following criteria:
Transmission, valve body or TCM replacement requires a Service Fast Learn procedure using a scan tool to be performed in order for the TCM to learn individual clutch apply pressures. If the TCM calibration has been updated, a Service Fast Learn procedure is required on vehicles with any mileage accumulation.
Clutch Drive Learn Procedure
Based on the bookmarks placed in the GDS2 session, complete the Clutch Drive Learn procedure for the suspect clutch. The Clutch Drive Learn procedure should only be performed on smooth, level roads and may take 45 minutes or more.
Completion of the Service Fast Learn procedure will reset all shift adapts and may require the entire transmission Clutch Drive Learn procedure for each clutch to be completed.
After completing the procedure, the vehicle should be allowed to cool down for eight or more hours and then test driven again to ensure the cold shift quality is acceptable.
Refer to the following bulletins for more information:
Garage Shifts
– Thanks to Terry Neuendorf
Article ID: 1380
Created: August 24, 2017
Last Updated: August 24, 2017
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-gm-techlink-diagnostic-tips-for-harsh-shifting-transmission-conditions-1380.html
