Subject: | Convertible Top Creak or Snap Noise While Driving |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Chevrolet |
Corvette Convertible |
2014 |
2016 |
All |
All |
Involved Region or Country |
North America, Japan, Europe, Middle East, Russia |
Condition |
Some customers may comment on hearing a creak or snapping noise from the convertible top while driving their vehicle. The noise may be loudest when the vehicle has sat in the sun for a length of time. |
Cause |
![]() The cause of the condition may be that the fasteners (1) at the ends of the #3 Bow (2) may have lost torque. |
Correction |
![]() Following the Service Procedure below, remove the original smaller screws and install the new larger M6 screws referenced in the Part Table. |
Warning: Due to bleed off of the hydraulic pressure, the folding top will have to be supported or held in mid-position by an assistant. Manual operation of the top cannot be attempted for at least 5 minutes from the last time of activation.
Note: It will be necessary to use a small wrench or tool similar to the graphic example above, in order to access the screws.
Important: Replace the screws one at a time. DO NOT remove or loosen all 3 screws on one side, at the same time.
Causal Part |
Description |
Part Number |
Qty |
X |
BOLT, F/TOP FRT LAT STKR |
11549154 |
6 |
For vehicles repaired under the Bumper-to-Bumper coverage (Canada Base Warranty coverage), use the following labor operation. Reference the Applicable Warranties section of Investigate Vehicle History (IVH) for coverage information.
Labor Operation |
Description |
Labor Time |
6080238* |
#3 Bow Retaining Screws Replacement |
0.6 hr |
*This is a unique Labor Operation for Bulletin use only. |
Article ID: 1381
Created: September 4, 2017
Last Updated: September 4, 2017
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-17-na-278-convertible-top-creak-or-snap-noise-while-driving-1381.html
