Subject: Front End Roll During Hard Cornering
Model and Year: 1968 Corvette with RPO L-88
Source: E.S.L. Bulletin
Bulletin No: 963 (T.N.)
Date: 68-10-3
FRONT END ROLL DURING HARD CORNERING - 1968 Corvette w/RPO L88
(#963) (T.N.)
It has come to our attention that the base production 327 type front stabilizer shaft could have been installed on some L88 equipped Corvettes built before 5-2-68. This installation can result in a reduction of front roll stiffness which may be noticeable to the more astute driver. In the event of a complaint of this nature, the front stabilizer shaft diameter should be measured. If the shaft measures 3/4" diameter instead of 15/16" diameter, then the following parts should be installed:
QUANTITY PART NO. NAME
1 3831972 Front Stabilizer Shaft (15/16" diameter)
2 3923674 Bushing
Article ID: 143
Created: July 6, 2014
Last Updated: July 6, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-l88-esl-bulletin-front-end-roll-during-hard-cornering-143.html
