Subject: Stripped Speedometer Driven Gear
Model and Year: 1974 - 1975 Corvette with 4-Speed Transmission
Bulletin No: 75-T-3
Section: XII
Date: January 17, 1975
To: All Chevrolet Dealers:
On 1974 and 1975 Corvettes with 4-speed transmission, an inoperative speedometer due to a stripped riven gear may be the result of high internal friction in the speedometer adapter.
A new low friction adapter and key will be phased into production in January, 1975 and will be available for service under the numbers listed below:
1565211 ---- Adapter
6476970 ---- Key
For service, vehicles exhibiting this problem may be corrected by the following method:
Article ID: 144
Created: July 6, 2014
Last Updated: July 6, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-1975-corvette-service-bulletin-stripped-speedometer-driven-gear-144.html
