Subject: | Information on Charge Air Cooler (CAC) Draining and Filling - DTC P0300 Set |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Chevrolet |
Camaro |
2017 |
2021 |
6.2L (LT4) |
Corvette |
2016 |
2019 |
6.2 L (LT4), 5.7L (LT5) |
Involved Region or Country |
North America, Middle East, Europe, Russia, Israel, Palestine, Argentina, Brazil, Chile, Colombia, Paraguay, Peru, Uruguay, Japan, GM Korea Company, China, Thailand |
Condition |
Some customers may comment that the engine misfires when the ambient temperature is high and the vehicle is traveling over 160 km/h (100 mph) on a track. Some technicians may find DTC P0300 set. |
Cause |
This condition may be caused by the supercharger’s cooling system not properly evacuated of all the air after a previous repair or service to the system. |
Correction |
If the supercharger’s cooling system has been previously repaired, it must be properly evacuated and filled using the following special tools:
The 6.2L V8 engine (RPO LT4), available in 2017-2021 Camaro ZL1 and Corvette models, features an Eaton Roots-type supercharger that creates a maximum boost pressure of 67 kPa (9.7 psi). The air entering the supercharger is cooled by an integral intercooler to enhance the effectiveness of the supercharger. The intercooler uses conventional coolant in a system that is separate from the engine cooling system. It includes two charge air coolers/heat exchangers, a water manifold assembly, and a variety of sensors to monitor air temperature and pressure.
If the supercharger cooling system is not properly evacuated and filled after service, DTC P0300 (Engine Misfire Detected) may set at high ambient temperatures during track speeds above 160 km/h (100 mph).
Refer to Charge Air Cooling System Draining and Filling in SI.
No parts are required for this repair.
Version |
2 |
Modified |
Released December 20, 2017 October 09, 2020 – Removed 2016 Model Year for Camaro, added 2019 - 2021 Model Years to Camaro, 2019 Model Year to Corvette, Engine RPO LT5 and updated the Involved Region or Country section. |
Article ID: 1454
Created: October 12, 2020
Last Updated: October 12, 2020
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2019-corvette-z06-zr1-service-bulletin-17-na-408-information-on-charge-air-cooler-cac-draining-and-filling-dtc-p0300-set-oct-9-2020-1454.html
