Subject: | N202307691 — Seat Belt May Not Lock in a Crash — GM Company Owned Vehicles Only |
Models: | 2020 Chevrolet Corvette |
Release Date: October 2020 |
Revision: 00 |
Attention: |
This bulletin covers vehicles that are currently GM Company-owned vehicles and that should be repaired will internally by GM. However, if for any reason these vehicles happen to enter your dealership with the this recall still open, use this bulletin to complete the remedy and close the VIN. |
Make |
Model |
Model Year |
RPO |
Description |
From |
To |
Chevrolet |
Corvette |
2020 |
2020 |
If these vehicles were not repaired internally by GM, they will be marked "open" on the Investigate Vehicle History screen in GM Global Warranty Management system. This site should always be checked to confirm vehicle involvement prior to beginning any required inspections and/or repairs.
Condition |
General Motors has decided that a defect which relates to motor vehicle safety exists in certain 2020 model-year Chevrolet Corvette vehicles. The seat-belt supplier for these vehicles inadvertently manufactured certain pretensioner components that were deformed and out of specification. That deformation may result in the retractor not locking following normal deployment of the pretensioner. As a result, the seat-belt retractor may not properly restrain the driver and/or passenger in a high-speed impact. If the seat belt does not lock during a high-speed crash, the driver and/or passenger may not be restrained as designed, increasing the risk of injury. |
Correction |
Dealers will replace the seat-belt retractor(s) as indicated in the table at the end of this bulletin. Note: Refer to the application chart at the end of this bulletin to determine the seating position that requires a seat belt retractor replacement. |
Quantity |
Part Name |
Part No. |
1 |
Retractor Kit- Front Seatbelt |
84609046 |
1 |
84753998 |
1 |
84609047 |
1 |
84609048 |
1 |
84754000 |
1 |
84609049 |
1 |
84754001 |
1 |
84609050 |
1 |
84754002 |
1 |
84609051 |
1 |
84754003 |
Note: Use the vehicle identification number (VIN) and the GM Electronic Parts Catalog (EPC) to determine which front seat belt retractor kit to order.
It is estimated that only 7 vehicles will require parts replaced. Due to the small number of vehicles anticipated that will need this fix and the limited initial parts availability, dealers are encouraged not to order these parts for use as shelf stock.
Reminder: Parts may be removed from Retail Inventory Management (RIM). Dealers should review the affected parts to confirm RIM managed status. Parts may have quantity limiters in effect.
Labor Operation |
Description |
Labor Time |
Trans. Type |
Net Item |
9105312 |
Replace Driver Side Front Seat Belt Retractor Assembly (Includes Pretensioner Disposal) |
1.1 |
ZFAT |
N/A |
9105313 |
Replace Driver and Passenger Side Front Seat Belt Retractor Assembly (Includes Pretensioner Disposal) |
1.9 |
ZFAT |
N/A |
Note: Refer to the application chart at the end of this bulletin to determine the seating position that requires a seat belt retractor replacement. Most vehicles will require the driver side only, but certain vehicles will require both the driver and passenger side seat belt retractors to be replaced.
Replace the driver side front seat belt retractor assembly, and if identified on the application chart, the passenger side front seat belt retractor assembly. Refer to Front Seat Belt Retractor Replacement (Coupe) in SI.
It is a violation of Federal law for a dealer to deliver a new motor vehicle or any new or used item of motor vehicle equipment (including a tire) covered by this notification under a sale or lease until the defect or noncompliance is remedied.
The US National Traffic and Motor Vehicle Safety Act provides that each vehicle that is subject to a recall of this type must be adequately repaired within a reasonable time after the customer has tendered it for repair. A failure to repair within sixty days after tender of a vehicle is prima facie evidence of failure to repair within a reasonable time. If the condition is not adequately repaired within a reasonable time, the customer may be entitled to an identical or reasonably equivalent vehicle at no charge or to a refund of the purchase price less a reasonable allowance for depreciation. To avoid having to provide these burdensome remedies, every effort must be made to promptly schedule an appointment with each customer and to repair their vehicle as soon as possible. In the recall notification letters, customers are told how to contact the US National Highway Traffic Safety Administration if the recall is not completed within a reasonable time.
All new, used, GM Certified Used, courtesy transportation vehicles, dealer shuttle vehicles, etc. in dealers’ possession and subject to this recall must be held and inspected/repaired per the service procedure of this bulletin before customers take possession of these vehicles. Involved vehicles must be held and not delivered to customers, dealer-traded, released to auction, used for demonstration, or any other purpose.
All GM Certified Used vehicles currently in the dealers’ inventory within the Certified Pre-Owned Inventory System (CPOIS) will be de-certified andmust be held and remedied per the service procedure in this bulletin. Upon submitting an accepted/paid warranty transaction in the Global Warranty Management (GWM) system, the vehicle can be re-certified for sale within the CPOIS system, or once again be used in the CTP program.
Dealers are to service all vehicles subject to this recall at no charge to customers, regardless of mileage, age of vehicle, or ownership, from this time forward.
Customers who have recently purchased vehicles sold from your vehicle inventory, and for which there is no customer information indicated on the dealer listing, are to be contacted by the dealer. Arrangements are to be made to make the required correction according to the instructions contained in this bulletin. Recall follow-up cards should not be used for this purpose, since the customer may not as yet have received the notification letter.
In summary, whenever a vehicle subject to this field action enters your vehicle inventory you must take the steps necessary to ensure the program correction has been made before selling the vehicle. In addition, for vehicles entering your facility for service, you are required to ensure the customer is aware of the open field action and make every reasonable effort to implement the program correction as set forth in this bulletin prior to releasing the vehicle.
For dealers with involved vehicles, a listing has been prepared and will be available through GM GlobalConnect Maxis Field Action Reports or sent directly to export dealers. The Inventory tab of the dealer reports will contain VINs that apply to this recall. This information is intended to assist dealers with the PROMPT COMPLETION of these vehicles. The Customer In-Service tab will contain customer names and addresses from Motor Vehicle Registration Records. The use of such motor vehicle registration data for any purpose other than follow-up necessary to complete this recall may be a violation of law in several states.
Courtesy transportation is available for customers whose vehicles are involved in a product program and still within the warranty coverage period. See General Motors Service Policies and Procedures Manual for courtesy transportation program details.
No customer notifications will be sent for these company owned vehicles.
VIN |
Position |
Driver |
Passenger |
1G1Y92D49L5000015 |
x |
x |
1G1Y82D40L5000018 |
x |
x |
1G1Y82D42L5000019 |
x |
x |
1G1Y82D40L5000021 |
x |
x |
1G1Y62D44L5000044 |
x |
x |
1G1Y72D4XL5000045 |
x |
1G1Y72D41L5000046 |
x |
x |
1G1Y72D43L5000047 |
x |
x |
1G1Y82D49L5000048 |
x |
1G1Y82D40L5000049 |
x |
1G1Y82D47L5000050 |
x |
1G1Y82D49L5000051 |
x |
1G1Y82D40L5000052 |
x |
1G1Y82D4XL5000074 |
x |
1G1Y92D45L5000075 |
x |
x |
1G1Y72D47L5000083 |
x |
x |
1G1Y72D42L5000086 |
x |
x |
1G1Y72D48L5000089 |
x |
1G1Y72D42L5000119 |
x |
1G1Y92D4XL5000153 |
x |
1G1Y82D48L5000154 |
x |
1G1Y92D43L5000155 |
x |
1G1Y82D43L5000160 |
x |
1G1Y82D47L5000162 |
x |
1G1Y82D49L5000163 |
x |
1G1Y82D40L5000164 |
x |
1G1Y82D46L5000167 |
x |
1G1Y92D41L5000204 |
x |
1G1Y82D4XL5000205 |
x |
1G1Y82D45L5000256 |
x |
1G1Y93D45L5000261 |
x |
1G1Y72D40L5000278 |
x |
1G1Y82D44L5105399 |
x |
1G1Y82D47L5105400 |
x |
Article ID: 1459
Created: October 15, 2020
Last Updated: October 15, 2020
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-safety-recall-seat-belt-may-not-lock-in-a-crash-gm-company-owned-vehicles-only-oct-13-2020-1459.html
