Subject: | Malfunction Indicator Lamp (MIL) Illuminated – DTCs P0521 and/or P06DD Set |
Brand: |
Model: |
Model Year: |
VIN Breakpoint: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Chevrolet |
Corvette |
2020 |
2020 |
SORP |
September 10, 2020 |
6.2L (LT2) |
Involved Region or Country |
North America |
Condition |
Some customers may comment that the MIL is illuminated. Some customers may also comment that the MIL will illuminate and then shut off. Some technicians may find one or more of the following DTCs set in the Engine Control Module (ECM):
Cause |
This condition may be caused by an unseated engine oil pressure control valve (OCV). |
Correction |
![]() Note: If a vehicle comes in with one of these DTCs, follow SI for both DTCs to ensure there is not an electrical fault or other hardware concern. After diagnosis has been performed and no issues are found electrically, then it will be necessary to remove the engine oil pan and inspect for a unseated engine oil pressure control valve, which is mounted on the bottom of the engine oil pump. If P0521 and P06DD DTCs are present, then a redesigned oil pressure control valve retainer clip (1) may be necessary. Refer to the Service Procedure section below. |
Note: The generator may need to be repositioned to gain access to the main cap side bolts.
Important: When removing the main bearing cap be careful not to damage the main bearing or journal surface of the crankshaft. Please set the main bearing cap in a safe place so no debris or damage could occur.
Note: Remove the existing oil pressure control valve retainer by pulling towards the rear and discard. You will be installing a newly designed retainer during installation.
Important: Do not use any tools to tap the pressure control valve into place. Only install the pressure control valve by pushing on the body of the valve by hand.
Tighten
TightenTighten the bolts to specifications. Refer to Fastener Specifications in SI.
Important: **The Oil Pump Control Valve (OCV) Retainer can be obtained from the Warranty Parts Center (WPC) using the TSP Dealer Request Form located on Global Connect<Service Department<Service Forms Application<General Information tab<TSP Dealer Request Form. Instructions for submitting are on the form. Request WPC857.
Causal Part |
Description |
Part Number |
Qty |
X |
RETAINER, O/PMP FLOW CONT SOL VLV |
Request WPC857** |
1 |
N/A |
BOLT, RR CRADLE BR (M14X2X105) |
11561495 |
2 |
N/A |
BOLT, RR CRADLE BR (M10X1.5X115) |
11547752 |
4 |
N/A |
BOLT, RR SUSP CRADLE FRT (M14x99.21) |
11602517 |
2 |
N/A |
SEAL, OIL PAN HIGH PRESS PORT |
12621086 |
4 |
N/A |
GASKET, OIL PAN (SMALL GASKET) |
55577121 |
1 |
N/A |
Seal, OIL PAN FRT |
12695698 |
1 |
N/A |
BOLT, CR/SHF BALR |
11548720 |
1 |
N/A |
BOLT, CR/SHF BRG CAP (M10X2X96) |
11548076 |
2 |
N/A |
BOLT, CR/SHF BRG CAP (M10X2X82) |
11548075 |
2 |
N/A |
BOLT, CR/SHF BRG CAP (M8X1.25X25) |
11546565 |
2 |
N/A |
Oil, Engine |
Refer to EPC |
Refer to SI |
Version |
1 |
Modified |
Released October 23, 2020 |
Article ID: 1463
Created: October 26, 2020
Last Updated: October 26, 2020
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-179-malfunction-indicator-lamp-mil-illuminated-dtcs-p0521-and-or-p06dd-set-oct-23-2020-1463.html
