Subject: | Service Engine Light Misfire Engine Noise With DTC P0300 P0106 P0506 |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Cadillac |
Escalade |
2021 |
All |
All |
6.2 L87 |
All |
Chevrolet |
Camaro |
2020-2021 |
All |
All |
6.2 LT1 LT4 |
All |
Chevrolet |
Corvette |
2020 |
All |
All |
6.2 LT2 |
All |
Chevrolet |
Silverado |
2020-2021 |
All |
All |
5.3 L82 L84 6.2 L87 6.6 L8T |
All |
Chevrolet |
Suburban |
2021 |
All |
All |
5.3 L84 6.2 L87 |
All |
Chevrolet |
Tahoe |
2021 |
All |
All |
5.3 L84 6.2 L87 |
All |
GMC |
Sierra |
2020-2021 |
All |
All |
All |
GMC |
Yukon |
2021 |
All |
All |
5.3 L84 6.2 L87 |
All |
Involved Region or Country |
North America |
Condition |
A Vehicle may have a concern of service engine light, misfire and engine noise with possible of DTC P0300 P0106 P0506. |
Cause |
Possible broken valve spring. |
Note: If you suspect you have a valve spring concern please contact Technical Assistance at (866) 960-6006 (after providing your case number, please select prompt one for engine Drivability then, prompt one for gasoline engines) TAC will assist with issue verification and expediting parts. In Canada, contact the Canadian Technical Assistance Centre at the number you have been provided.
During inspection if you determine that the engine has a broken valve spring it will be necessary to perform a cylinder leakage test on the affected cylinder.
If no cylinder leakage is observed and the vehicle is built between June 1, 2020 to October 7, 2020:
Note: Brand Quality has placed the following Part number for 2020, 2021 6.2L L87, LT1, LT2, LT4 valve springs on a Technical Assistance Center part restriction
P/N 12691120 - 6.2L L87, LT1, LT2, LT4Please add any pictures of the concern to the case that will help with the diagnostics.
Check for a damaged intake manifold runner for the cylinder with the concern.
00-06-01-026M: Engine Replacement After Severe Internal Engine Damage -Replace Intake Manifold
If you determine that engine has cylinder leakage it will be necessary to inspect further to determine the extent of the engine damage to determine correct repair required;
Important: All valve springs will be requested back for further analysis and inspection.
For vehicles repaired under the Powertrain coverage, use published labor operation. Reference the Applicable Warranties section of Investigate Vehicle History (IVH) for coverage information.
Version |
7 |
Modified |
09/08/2020 - Created on. 09/21/2020 - Updated to add 2020 Chevrolet Camaro and edit the correction statement 10/13/2020 - Updated Model Years. 10/13/2020 - Updated Model Years. 10/16/2020 - Updated to add Admin. Details 10/21/2020 - Updated to add contact Technical assistance 10/23/2020 - Updated to add Valve Spring Part Restriction. 10/28/2020 - Updated to add MY 2021 for T1XX Pick up |
Article ID: 1465
Created: October 30, 2020
Last Updated: October 30, 2020
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-pip5752f-service-engine-light-misfire-engine-noise-with-dtc-p0300-p0106-p0506-oct-28-2020-1465.html
