2020 Corvette: Service Update: #N202319660: Service Update - Valve Spring Failure - (Nov 20, 2020)
Subject N202319660 — Valve Spring Failure
Models 2021 Cadillac Escalade (RPO L87)
2021 Chevrolet Camaro (RPO LT1/LT4)
2020 Chevrolet Corvette (RPO LT2)
2020–2021 Chevrolet Silverado 1500 (L87)
2021 Chevrolet Suburban (L87)
2021 Chevrolet Tahoe (L87)
2021–2021 GMC Sierra 1500 (RPO L87)
2021 GMC Yukon (L87)
Release Date: November 2020
Revision: 00
Attention:
This service update involves vehicles in dealer inventory only and will expire November 30, 2021.
Make
Model
Model Year
RPO
Description
From
To
Cadillac
Escalade
2021
2021
L87
Chevrolet
Camaro
2021
2021
LT1/LT4
Chevrolet
2020
LT2
Chevrolet
Silverado 1500
2020
2021
L87
Chevrolet
Suburban
2021
2021
L87
Chevrolet
Tahoe
2021
2021
L87
GMC
Sierra 1500
2020
2021
L87
GMC
Yukon
2021
2021
L87
This service update should be performed on vehicles in dealer inventory only. Involved vehicles are marked “open” on the Investigate Vehicle History screen in GM Global Warranty Management system. This site should always be checked to confirm vehicle involvement prior to beginning any required inspections and/or repairs.
Condition
Certain 2020 Chevrolet Corvette, 2020-2021 model year Chevrolet Silverado 1500, GMC Sierra 1500, and 2021 model year Cadillac Escalade, Chevrolet Camaro, Suburban, Tahoe, and GMC Yukon vehicles may present a broken engine valve spring. This may cause the engine to run rough, an engine knocking or ticking noise, a check engine light illumination, or a possible vehicle stall.
Correction
Dealers are to perform the inspection procedure contained within this bulletin.
Parts Information
Quantity
Part Name
Part No.
8
Engine Oil
88865907 US
19353384 CA
All Other Countries:
Obtain locally in compliance
with GM spec GMW17332
8
Engine Oil
19370233 US
19368925 CA
All other Countries: Obtain
locally in compliance with GM
spec GMW 16177 and Material
Specification 9986491
1
Engine Oil Filter
12690385
1
Engine Oil Filter
12706595
Note: Use the VIN and the GM Electronic Parts Catalog (EPC) to determine which engine oil and filter to use for the oil change.
Reminder: Parts may be removed from Retail Inventory Management (RIM). Dealers should review the affected parts to confirm RIM managed status. Parts may have quantity limiters in effect.
Warranty Information
Labor Operation
Description
Labor Time
Trans. Type
Net Item
9105434
Inspect Only
Add: Corvette Convertible
-If repairs or diagnosis are necessary, open another warranty line and perform them there under warranty.
5.7
0.1
ZFAT
9105460
Administrative Cost for Vehicles in Courtesy Transportation Only with more than 500 miles (800 km)
0.2
ZFAT
N/A
* The amount identified in “Net Item” should represent the actual sum total of the current GMCC&A Dealer net price for gasoline needed to perform the required repairs, not to exceed $51 USD, $66.72 CAD. This amount is not to exceed half a tank of premium gasoline per vehicle.
Important: The following inspection procedure does not need to be performed on any dealer courtesy or demo vehicle with 500 miles (800 km) or more. Please use labor code 9105460 to close the field action.
Inspection Procedure
  1. Ensure vehicle has a ½ tank of fuel minimum.
  2. Set vehicle up in a secure area where it cannot be stolen, with adequate ventilation (use exhaust vent hose if indoors) and open the hood or engine compartment lid. Keep vehicle away from any flammable surroundings or substances. Ensure the A/C is off. Finally, position a box fan blowing at the vehicle’s radiator.
  • Apply the brake and start the vehicle, holding the Engine Start/Stop button for at least 15 seconds.
  • Set up your laptop in the vehicle, plugging the charging cable into the vehicle’s 110v power plug (or use an extension cord if the vehicle is not so equipped), and the MDI 2 into the vehicle’s OBDII port.
  • Open Techline Connect and navigate through GDS2.
  • Using your phone or a timer you can keep near you, set a timer for 4 hours and 30 minutes and allow the vehicle to run.
  • Check on the vehicle at a minimum of 25-minute intervals to ensure it is still running, and run down the below checklist – the more often you can check on it, the better. The checklist includes:
  • If for some reason the vehicle does shut off during the test, restart it per the original instructions and continue the test from the time point where the vehicle shut off. It is not necessary to restart the entire test.
  • If any of these conditions are detected, immediately stop the test, immediately call the GM Technical Assistance Center for further instructions. For U.S. Dealers contact 877-446-8227. For Canadian Dealers contact 800-263-7740 (English) or 800-263-7960 (French). For International Dealers, if any of these conditions are detected, follow normal diagnostic and parts ordering procedures.
  • If 4.5 hours passes and none of these conditions are detected, replace any removed components and take the vehicle for a 10 mile test drive. Ensure the computer and MDI remain in the vehicle during this test drive so you can check DTCs if necessary. Utilize manual shifting mode for the entire duration of the test drive, attempting to keep RPM between 2000 and 3500 RPM. During the test drive, monitor for the below conditions. If any of these conditions are found during the test drive, immediately return to the dealership, keeping the engine RPM as low as possible and avoiding heavy throttle.
  • If both the high-idle test and the road test complete successfully without any of the above described issues, no further testing is required.
  • Perform an oil change. Refer to Engine Oil and Oil Filter Replacement in SI.
  • Dealer Responsibility
    Dealers must take the steps necessary to ensure that the service update correction has been made to all involved vehicles in dealer inventory before selling or dealer-trading the vehicle, but no later than November 30, 2021.
    All new, used, GM Certified Used, courtesy transportation vehicles, dealer shuttle vehicles, etc. in dealers’ possession and subject to this bulletin must be held and inspected/repaired per the service procedure of this bulletin before customers take possession of these vehicles.  Involved vehicles must be held and not delivered to customers, dealer-traded, released to auction, used for demonstration, or any other purpose.
    All GM Certified Used vehicles currently in the dealers’ inventory within the Certified Pre-Owned Inventory System (CPOIS) will be de-certified andmust be held and remedied per the service procedure in this bulletin.  Upon submitting an accepted/paid warranty transaction in the Global Warranty Management (GWM) system, the vehicle can be re-certified for sale within the CPOIS system, or once again be used in the CTP program.
    Dealer Reports
    The Inventory tab of the Open Vehicle Report will contain Service Update Bulletin VINs that apply to this field action. This information is intended to assist dealers with the PROMPT COMPLETION of these vehicles. The Customer In-Service tab will not contain Service Update Bulletin VIN data because the intent of a Service Update Bulletin is to not inconvenience a customer with a special trip for service. Service Update Bulletins are to be completed when the customer is in for a regularly scheduled visit.
    Article ID: 1472
    Created: November 23, 2020
    Last Updated: November 23, 2020
    Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-update-n202319660-service-update-valve-spring-failure-nov-20-2020-1472.html
