2014 - 2019 Corvette: Service Bulletin: #19-NA-217: Manual Transmission Stalling, Clutch Chatter and/or Hard Shifting into 1st Gear or Reverse; Automatic Transmission Vibration on Launch and/or Engine Noise - (Dec 21, 2020)
Subject Manual Transmission Stalling, Clutch Chatter and/or Hard Shifting into 1st Gear or Reverse; Automatic Transmission Vibration on Launch and/or Engine Noise
Brand:
Model:
Model Year:
VIN Breakpoint
Engine:
Transmission:
from
to
from
to
Chevrolet
2019
6.2L (LT1, LT4)
6L80 Automatic (MYC), 8L90 Automatic (M5U) or Manual
Involved Region or Country
North America, Europe, Russia, Middle East, Japan, Thailand
Condition
Important: If the vehicle came in with a rattle noise coming from the front of the vehicle when the engine is running at slower engine speeds and no other concerns, refer to Service Bulletin 18-NA-268.
Some customers may comment on any of the following conditions:
Note: On Automatic Transmission equipped vehicles, this may also happen after the driveline was replaced for another reason.
  • For Manual Transmission equipped vehicles:
    • Stalling
    • Clutch chatter
    • Hard shifting into 1st gear or Reverse
  • For Automatic Transmission equipped vehicles:
    • Vibration on takeoff
    • Clunk noise
Cause
This condition may be caused by excessive crankshaft endplay associated with a damaged thrust bearing.
  • Please use following information before considering an engine or crankshaft replacement.
Correction
If a vehicle comes in with the conditions listed above, refer to the Service Procedure below.
Note: Complete the SI diagnostics and the Cost Comparison Worksheet for Assembly Repair vs Replacement to determine if the engine requires a repair or replacement. DO NOT the replace engine assembly for this concern. Only replace the engine assembly if other damage is found.
Example of a good thrust bearing face.
Service Procedure
Important: Follow the service procedures outlined in Service Bulletin 18-NA-268 for DSA inspection and possible repair.
    1. Validate the crankshaft endplay is within specification (0.0015-0.0086 (0.040-0.220 mm).
  • Start with removing the middle thrust main bearing cap.
  • 2014 - 2019 Corvette: Service Bulletin: #19-NA-217: Manual Transmission Stalling, Clutch Chatter and/or Hard Shifting into 1st Gear or Reverse; Automatic Transmission Vibration on Launch and/or Engine Noise - (Dec 21, 2020)
      1. Inspect the thrust bearing for wear on one side and crankshaft on the corresponding mating surface. The graphic above shows an example of a damaged thrust bearing.
    Note: It is not necessary to replace the engine assembly for this condition.
  • Refer to Crankshaft and Bearing Removal in SI.
  • If bearing damage is found and if the vehicle is equipped with a dry sump system, it will be necessary to replace the oil tank with lines and oil cooler.
    Parts Information
    Causal Part
    Description
    Part Number
    Qty
    X
    CRANKSHAFT (LT1)
    12674745 (EXC Z52)
    1
    X
    CRANKSHAFT (LT1)
    12674744 (Z52)
    1
    X
    CRANKSHAFT (LT4)
    12674743
    1
    N/A
    BOLT, CR/SHF BRG CAP (M10X2X96) (LT1/LT4)
    11548076
    10
    N/A
    BOLT, CR/SHF BRG CAP (M10X2X82) (LT1/LT4)
    11548075
    10
    N/A
    BOLT, CR/SHF BRG CAP (M8X1.25X25 HEX FLANGE) (LT1/LT4)
    11546565
    10
    N/A
    SEAL, CR/SHF FRT OIL (LT1/LT4)
    12693255
    1
    N/A
    SEAL, CR/SHF RR OIL (LT1/LT4)
    89060436
    1
    N/A
    BEARING KIT, CR/SHF (LT1/LT4)
    12656814
    1
    N/A
    BEARING KIT, CONN ROD (LT1/LT4)
    12683811
    1
    N/A
    BEARING, CLU/PILOT (Manual Transmission Only) (LT1/LT4)
    12557583
    1
    N/A
    TNK, ENG OIL (LT1/LT4 Dry Sump Only Z52)
    12680701
    1
    N/A
    HOSE, AUX ENG OIL TK INL
    23299434
    1
    N/A
    HOSE, AUX ENG OIL TK OTLT
    23299435
    1
    N/A
    BOLT, A/TRANS FLEX PLT (M11X1.5X19) (LT1/LT4)
    11547118
    8
    N/A
    OIL, Engine
    Refer to EPC
    N/A
    FILTER, OIL
    Version
    3
    Modified
    Released February 4, 2020
    March 24, 2020 – Added CRANKSHAFT (LT1) 12674744 (Z52) to the Parts Information section and corrected P/N 11547188 to 11547118.
    December 21, 2020 – Updated some quantities in the Parts Information section.
    Article ID: 1480
    Created: December 22, 2020
    Last Updated: December 22, 2020
    Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-19-na-217-manual-transmission-stalling-clutch-chatter-and-or-hard-shifting-into-1st-gear-or-reverse;-automatic-transmission-vibration-on-launch-and-or-engine-noise-dec-21-2020-1480.html
