2020 Corvette: Service Bulletin: #20-NA-236: Engine Overheats or Coolant Leak Under Rear of Vehicle - (Feb 10, 2021)
Subject Engine Overheats or Coolant Leak Under Rear of Vehicle
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
2020
6.2L (RPO LT2)
Involved Region or Country
North America, Middle East
Condition
Some customers may comment on one or more of the following conditions:
  • Engine overheats
  • Coolant leak under rear of vehicle
Cause
This condition may be caused by the water pump outlet pipe becoming disconnected from the water pump.
Correction
Important: Follow the complete coolant bleed process called out in SI. Performing just a vac-n-fill will leave air in the cooling system, potentially causing an overheat condition.
Replace the water pump outlet pipe and fully perform the complete bleed procedure after replacing the pipe.
Service Procedure
Refer to Water Pump Outlet Pipe Replacement - Engine Coolant Manifold to Engine Oil Cooler Adapter in SI.
Parts Information
Causal Part
Description
Part Number
Qty
X
PIPE, W.PMP OTLT
84660333
1
N/A
DEX-COOL®
Refer to EPC
1
Version
1
Modified
Released February 10, 2021
Article ID: 1490
Created: February 11, 2021
Last Updated: February 11, 2021
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-corvette-service-bulletin-20-na-236-engine-overheats-or-coolant-leak-under-rear-of-vehicle-feb-10-2021-1490.html
