Subject: | N202321570 - Incorrect Front Suspension Lift Reservoir Cap - Export Only |
Models: | 2020 - 2021 Chevrolet Corvette |
Release Date: March 2021 |
Revision: 00 |
Attention: |
This program is in effect until March 31, 2023. |
Make |
Model |
Model Year |
RPO |
Description |
From |
To |
Chevrolet |
Corvette |
2020 |
2021 |
Involved vehicles are marked “open” on the Investigate Vehicle History screen in GM Global Warranty Management system. This site should always be checked to confirm vehicle involvement prior to beginning any required inspections and/or repairs.
Condition |
Certain 2020 and 2021 model year Chevrolet Corvette vehicles, may have been built with an incorrect Front Suspension Lift Reservoir cap. |
Correction |
Dealers are to replace the suspension fluid reservoir cap. |
Quantity |
Part Name |
Part No. |
1 |
CAP-HYD SUSP FLUID RSVR |
85165040 |
Important: Due to limited initial parts availability, dealers are encouraged not to order these parts for use as shelf stock.
It is estimated that there are only 149 involved vehicles that will require parts being replaced. Due to the small number of vehicles anticipated that will need this repair and the limited initial parts availability, dealers are encouraged not to order these parts for use as shelf stock.
Warning: Refer to Brake Fluid Irritant Warning in SI.
Caution: Refer to Brake Fluid Effects on Paint and Electrical Components Caution in SI.
Note: Note: Clean the filler cap and surrounding area before removing the cap.
All new, used, GM Certified Used, courtesy transportation vehicles, dealer shuttle vehicles, etc. in dealers’ possession and subject to this program must be held and inspected/repaired per the service procedure of this bulletin before customers take possession of these vehicles. Involved vehicles must be held and not delivered to customers, dealer-traded, released to auction, used for demonstration, or any other purpose.
All GM Certified Used vehicles currently in the dealers’ inventory within the Certified Pre-Owned Inventory System (CPOIS) will be de-certified andmust be held and remedied per the service procedure in this bulletin. Upon submitting an accepted/paid warranty transaction in the Global Warranty Management (GWM) system, the vehicle can be re-certified for sale within the CPOIS system, or once again be used in the CTP program.
Dealers are to service all vehicles subject to this program at no charge to customers, regardless of mileage, age of vehicle, or ownership, through March 31, 2023. Customers who have recently purchased vehicles sold from your vehicle inventory, and for which there is no customer information indicated on the involved vehicle listing, are to be contacted by the dealer. Arrangements are to be made to make the required correction according to the instructions contained in this bulletin. A copy of the customer letter is provided in this bulletin for your use in contacting customers. Program follow-up cards should not be used for this purpose, since the customer may not as yet have received the notification letter.
In summary, through March 31, 2023, whenever a vehicle subject to this field action enters your vehicle inventory you must take the steps necessary to ensure the program correction has been made before selling the vehicle. In addition, for vehicles entering your facility for service, you are required to ensure the customer is aware of the open field action and make every reasonable effort to implement the program correction as set forth in this bulletin prior to releasing the vehicle.
For dealers with involved vehicles, a listing has been prepared and will be available through GM GlobalConnect Maxis Field Action Reports or sent directly to export dealers. The Inventory tab of the dealer reports will contain VINs that apply to this field action. This information is intended to assist dealers with the PROMPT COMPLETION of these vehicles. The Customer In-Service tab will contain customer names and addresses from Motor Vehicle Registration Records. The use of such motor vehicle registration data for any purpose other than follow-up necessary to complete this field action may be a violation of law in several states.
Export - Letters will be sent to known owners of record located within areas covered by the US National Traffic and Motor Vehicle Safety Act. For owners outside these areas, dealers should notify customers using the attached sample letter.
March 2021
This notice applies to your vehicle, VIN:_____________________________________
Dear General Motors Customer:
We have learned that your 2020 or 2021 model year Chevrolet Corvette may have been built with an incorrect Front Suspension Lift Reservoir cap.
Your satisfaction with your Corvette is very important to us, so we are announcing a program to prevent this condition or, if it has occurred, to fix it.
What We Will Do: Your GM dealer will replace the suspension reservoir cap. This service will be performed for you at no charge until March 31, 2023. After that, any applicable warranty will apply.
What You Should Do: To limit any possible inconvenience, we recommend that you contact your dealer as soon as possible to schedule an appointment for this repair. By scheduling an appointment, your dealer can ensure that the necessary parts will be available on your scheduled appointment date.
If you have any questions or need any assistance, just contact your dealer or the appropriate Customer Assistance Center at the number listed below.
Division |
Number |
Text Telephones (TTY) |
Chevrolet |
1-800-630-2438 |
1-800-833-2438 |
Puerto Rico – English |
1-800-496-9992 |
Puerto Rico – Español |
1-800-496-9993 |
Virgin Islands |
1-800-496-9994 |
We truly appreciate you taking the time to remedy your vehicle as we know your time is valuable. We want you to know that we will do our best, throughout your ownership experience, to ensure that your Corvette provides you many miles of enjoyable driving.
Neelie O’Connor
Global Executive Director
Customer Experience Operations
N202321570
Article ID: 1495
Created: March 10, 2021
Last Updated: March 10, 2021
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2020-2021-corvette-recall-n202321570-customer-satisfaction-program-incorrect-front-suspension-lift-reservoir-cap-export-only-mar-8-2021-1495.html
