Subject: | Concern Of An Engine Thermostat Tick Noise And/Or Running Hot |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Cadillac |
CTS-V |
2016 - 2019 |
All |
All |
6.2L LT4 |
All |
Cadillac |
Escalade |
2015-2020 |
All |
All |
6.2L L86 |
All |
Cadillac |
Escalade |
2021 |
All |
All |
6.2L L87 |
All |
Chevrolet |
Camaro |
2016-2021 |
All |
All |
6.2L LT1 LT4 |
All |
Chevrolet |
Corvette |
2014 - 2019 |
All |
All |
6.2L LT1 LT4 LT5 |
All |
Chevrolet |
Corvette |
2020 - 2021 |
All |
All |
6.2L LT2 |
All |
Chevrolet |
Silverado LD |
2014-2019 |
All |
All |
4.3L LV3 5.3L L83 6.2L L86 |
All |
Chevrolet |
Silverado (New Model) |
2019-2021 |
All |
All |
5.3L L82 L84 6.2L L87 |
All |
Chevrolet |
Suburban |
2015-2020 |
All |
All |
5.3L L83 |
All |
Chevrolet |
Suburban |
2021 |
All |
All |
5.3L L84 6.2L L87 |
All |
Chevrolet |
Tahoe |
2015-2020 |
All |
All |
5.3L L83 |
All |
Chevrolet |
Tahoe |
2021 |
All |
All |
5.3L L84 6.2L L87 |
All |
GMC |
Sierra Limited |
2014-2019 |
All |
All |
All |
GMC |
Sierra (New Model) |
2019-2021 |
All |
All |
All |
GMC |
Yukon Models |
2015-2019 |
All |
All |
5.3L L83 6.2L L86 |
All |
GMC |
Yukon Models |
2021 |
All |
All |
5.3L L84 6.2L L84 |
All |
This PI was superseded to update Model Years. Please discard PIP5212B.
A vehicle may have a concern of the engine running hot and/or has a tick noise from the thermostat.
Inspect the position of the head gasket locating tabs, to determine if the head gasket(s) has been possibly installed backwards.
Per the attached pictures, the head gasket locating tabs for both of the engine cylinder banks should be toward the front of the engine.
1. Bank 1 tab near cylinder 3
2. Bank 2 tab near cylinder 4
3. Is the front of the engine
If the head gasket locating tabs are found to be closer to cylinders 5 or 6, this indicates the head gaskets were installed incorrectly restricting the engine coolant flow.
Replace the head gasket to repair for this concern.
Note: GEN5+ engines (L82, L84, L87 all model years).
This noise can sound more like a scraping noise (similar to a failed bearing type noise)on these engines, generally the techs are hearing it from the water pump area and it goes away when the belt is removed. Most likely the noise showed up after the heads had been recently removed (we haven’t seen any that were built that way from the factory).
Article ID: 1502
Created: March 31, 2021
Last Updated: March 31, 2021
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2021-corvette-service-buletin-pip5212c-concern-of-an-engine-thermostat-tick-noise-and-or-running-hot-mar-30-2021-1502.html
