Subject: | Diagnostic Tip for a B1517 DTC |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Chevrolet |
Corvette |
2014 - 2019 |
All |
All |
All |
All |
Involved Region or Country |
North America |
Condition |
The reason that a vehicle has been brought into the dealership may vary widely. |
Cause |
During the initial diagnosis, a technician may find a B1517 set in one of the vehicles listed above. |
If a B1517 is found set in any module, or even multiple modules, dealership technicians are to first inspect the battery cable connections. In many cases, the small black wire that connects to the larger battery negative cable is loose or damaged. If the vehicle history is reviewed, or the customer is further questioned, it will usually be found that a battery was recently replaced in the vehicle. This may have been done by a tech unfamiliar with the vehicle, a different shop, or even by the customer himself.
Closely inspect the small black wire seen in the photo below. It may be loose, rotated, or pulled out of the actual terminal. Any loose connection or damage to this circuit may cause a B1517, especially with a symptom 5A.
It should also be noted that this is not a manufacturing concern, but rather this issue is caused by improper service work that was previously done on the vehicle. Resecure / repair the connection as needed.
Version |
1 |
Modified |
06/25/2021 Created on. |
Article ID: 1521
Created: June 28, 2021
Last Updated: June 28, 2021
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2019-corvette-service-bulletin-pic6439-diagnostic-tip-for-a-b1517-dtc-battery-negative-cable-jun-25-2021-1521.html
