Date: October 18, 2006
Bulletin #: #06-02-32-012B
Subject: Power Steering Shudder or Vibration at Idle (Replace Power Steering Inlet (Pressure) Hose)
Models: 2005-2007 Chevrolet Corvette with Automatic Transmission
Condition
Some customers may comment on a shudder/vibration while rotating the steering wheel at idle. This vibration can be very minor to where it is only felt in the steering wheel or major enough to notice a slight shake in the interior components. Rougher road surfaces can increase the intensity as it increases the drag against the wheels as they attempt to turn. Slightly raising the engine idle should eliminate the vibration.
Cause
At idle, turning the wheels causes the steering pressures to raise high enough to cause a load on the engine. The load is great enough to cause the idle to become rough and it can be felt in the vehicle.
Correction
Replace the power steering inlet (pressure) hose with the part number listed below.
For vehicles with either FE1 or FE2 suspension, a retaining clip, P/N 88967174, is also required. After installing the new hose, attach the clip to the hose just before the crimp, as shown. Secure the other end of the clip to the existing power steering return line.
15903239 (FE1/FE2 Suspension)Power Steering Inlet (Pressure) Hose
15903240 (FE3/FE4 Suspension) Power Steering Inlet (Pressure) Hose
88967174 Clip FE1/FE2 Suspension
© Copyright General Motors Corporation. All Rights Reserve
Article ID: 153
Created: July 6, 2014
Last Updated: July 6, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2007-corvette-service-bulletin-power-steering-shudder-or-vibration-at-idle-153.html
