Subject: Low Coolant Warning Light
Number: 88-43
Section: 6B
Date: Sept., 1987
Models: 1986-88 Corvettes
To: All Chevrolet Dealers
This bulletin cancels and supersedes Dealer Service Bulletin 87-11 (Section 6B) dated Oct., 1986. All copies of 87-11 should be destroyed. Additional procedures regarding thermal cycling are provided in this bulletin.
Low coolant light illumination on 1986-88 Corvettes which appear to have an adequate amount of coolant may be caused by air trapped in the coolant system.
If the low coolant light is on continuously during all driving conditions, the coolant light circuit should be checked for proper function. This can be done by disconnecting the wire at the coolant probe and grounding the wire to the chassis. If the light does not go out, check for broken or loose wires or a faulty low coolant module.
Procedure
Part Number | Description | Quantity Required |
10054615 | Low Coolant Sensor Probe | 1 |
22527587 | Hose Clamp (screw type aircraft) | 2 |
If this procedure does not repair the low coolant light condition, the total cooling system should be checked for insufficient hose clamping or leaks, including checking the crankcase engine oil for traces of coolant which would indicate an internal engine leak of the coolant. Repeat thermal cycle procedure after repairs are completed.
Use applicable labor operation time and number.
Article ID: 161
Created: July 13, 2014
Last Updated: July 13, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-low-coolant-warning-light-161.html
