Subject: Yellowing Paint on or Around Headlamp Doors (White Only)
Model and Year: 1988 - 1989 "Y" CAR (CORVETTE)
Bulletin Number: 89-136-10
Date: 06-apr-1989
Some customers may comment regarding the yellowing of paint on or around the headlamp doors on 1988 - 1989 Corvettes (WHITE PAINT ONLY). This condition is due to a reaction of the clear coat to some rubber components in the engine compartment.
IMPORTANT:
To correct this condition, a new service kit, P/N 10105330, is available from GMSPO and contains the following parts:
1 - Radiator hose, inlet | 1 - A.I.R. hose, to check valve |
1 - Radiator hose, outlet | 1 - A.I.R. hose, to cat. conv. |
1 - Heater hose, inlet | 1 - A.I.R. hose, ck/valve/silencer |
1 - Heater hose, outlet (less KC4) |
1 - A.I.R. hose, to check valve 1 - Throttle body coolant hose |
1 - Heater hose, outlet (with KC4) |
1 - Belt, accessory drive |
REPAIR PROCEDURE: (Use on vehicles with VINs prior to J5120731.)
In addition to the installation of the kit, both headlamp doors should be replaced. New headlamp door, P/N 10137733 (left) and 10137734 (right) are available from GMSPO.
It may also be necessary to repaint the right side headlamp bezel only, if heavier yellowing conditions are present. See the PAINTING section later described in this bulletin.
REPAIR PROCEDURE: (Use on vehicles with VINs after J5120731 but prior to K5113927.)
PAINTING
Depending on the amount of yellowing condition, a number of repairs are possible.
PAINT YELLOWING
HEAVIER YELLOWING
More severe yellowing may require either "spot/partial panel repair" procedures. Please refer to past "PRO TECH" publication, PROGRAM CV9-1-(88-8), CORVETTE REFINISHING TECHNIQUES.
© Copyright General Motors Corporation. All Rights Reserve
Article ID: 164
Created: July 13, 2014
Last Updated: July 13, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-yellowing-paint-on-or-around-headlamp-doors-white-only-164.html
