Subject: FUEL ECONOMY DROP - #7014800 FUEL INJECTION UNIT
Model and Year: 1957 - 1958 Corvette
Source: Chevrolet Central Office Technical Service bulletin
Bulletin Number: DR #329
Section: VIm
Date: November 21, 1957
Progressive and gradual lowering of Fuel Economy on units equipped with #7014800 Fuel Injection may be due to partial restriction of the .030" venturi signal bleed hole in the air meter.
A dirt build up at this point gradually reduces the amount of signal bleed off, resulting in a progressively stronger venturi signal and increased enrichment.
The following procedure is recommended for cleaning the bleed hole. (Reference 1958 Passenger Car Shop Manual, Page 10-74, Figure 136).
Article ID: 165
Created: July 13, 2014
Last Updated: July 13, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1958-corvette-service-bulletin-fuel-economy-drop-rochester-fuel-injection-service-update-165.html
