Subject: Loss of Oil Pressure
Model and Year: 1962 Corvette 250 H.P. 327" V-8
Bulletin Number: TSB #838
Section: VI
Date: October 16, 1962
TO: ALL CHEVROLET SERVICE PERSONNEL
If loss of engine oil pressure occurs at high engine R.P.M. on 1962 Corvette units with the base 250 H.P. 327 cu. in. engine, the problem may be eliminated by adding an oil pan Upper Baffle, Part No. 3769768. This is the baffle used on High Performance engines.
In order to install this baffle, five (5) Part No. 3769769 Special Studs are used - two at #2 main bearing cap, two at #3 main bearing cap and one at the right hand side of #4 main bearing cap. The oil pump attaching bolt is used for the rearmost attachment.
1963 Corvette with the base engine will incorporate an improved design oil pan with added baffles to prevent any recurrence of this problem.
ADJ/afm
c: TSBList
Mr. C. M. Sagley
Chevrolet Motor Division,
General Motors Corporation,
P.O. Box 539
Salt Lake City 10, Utah.
Part No. | Required | Description |
3769768 | 1 | Baffle, Oil Pan Upper |
3769769 | 5 | Stud, Special |
9414034 | 5 | 3/8" - 16 Hexagon Nut (Available in Lots of 100 only) |
138489 | 5 | 3/8" Lock Washer, External Tooth (Available in Lots of 100 only) |
Article ID: 176
Created: July 13, 2014
Last Updated: July 13, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-loss-of-oil-pressure-176.html
