Service Bulletin #: 06-02-35-002
Date: January 2006
Subject: Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC) (Inspect and Secure Wires in SWPS Connector)
Model(s):
2004 - 2006 Cadillac XLR
2005 - 2006 Chevrolet Corvette
with Steering Wheel -- Tilt, Telescoping (RPO N37)
Article ID: 216
Created: July 14, 2014
Last Updated: July 14, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-diagnostic-trouble-code-dtc-c0710-steering-wheel-position-sensor-swps-signal-service-stability-system-message-on-driver-information-center-dic-216.html
