Service Bulletin #: 04-08-44-024
Removal of Radio Fuse Before Attempting to Program/Reprogram Modules Using Service Program System (SPS)
2005 Chevrolet Corvette with CD Player or Changer AM/FM with MP3 Player (RPO US8 or US9)
Important:
• Failure to remove the radio fuse prior to programming/reprogramming any module using the SPS service procedure may result in an inoperative radio.
• DO NOT remove the radio fuse when programming/reprogramming the radio.
The radio may interrupt Class-2 programming and/or reprogramming of other modules on the buss.
Prior to programming/reprogramming any module using the SPS service procedure, the technician is required to remove the radio fuse.
2005 -- Corvette
Remove the Radio/S-Band/VICS 15-amp fuse from the I/P electrical center (passenger side) prior to SPS reprogramming.
Program/Reprogram the appropriate module that requires service.
Reinstall the radio fuse.
Article ID: 343
Created: July 18, 2014
Last Updated: July 18, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-removal-of-radio-fuse-before-attempting-to-program-reprogram-modules-using-service-program-system-sps-343.html
