Service Bulletin #: 04-08-44-023
CD Won’t Play Above A Certain Track Number (Temporary Fix -- Remove/Reinstall Fuse; Permanent Fix Under Development)
2005 Chevrolet Corvette with RPO US8 - Radio or US9 - Radio
Condition
Some customers may comment that the CD will not play above a certain track number.
Cause
This condition may be caused by a software anomaly in the radio preventing further tracks to be recognized. For example, if an MP3 disc with 7 tracks is played, the next "regular" CD audio disc played will only play up to 7 tracks.
Correction
Engineering is working to develop and validate a software fix for this condition. Until such time the software is available, use the following procedure as a "short-term" fix.
2005 -- Corvette
Remove the Radio/S-Band/VICS 15-amp fuse from the I/P electrical center (passenger side) for 30 seconds.
Reinstall fuse.
Advise the customer that the issue may return if they utilize another MP3 disc that contains less than 30 tracks/files. If an MP3 disc with more than 30 tracks/files is inserted into the CD player/changer, this will also resolve the issue.
Article ID: 345
Created: July 18, 2014
Last Updated: July 18, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-cd-won-t-play-above-a-certain-track-number-345.html
