Subject: Tire Pressure Monitoring System (TPMS) Grommet/Seal Availability
Number: 03-03-10-004 - (04/07/2003)
Models:1999-2003 Chevrolet Corvette
2000-2003 Cadillac DeVille, DHS, DTS, Seville
Do not replace the wheel mounted Tire Pressure Monitoring Module if the grommet requires replacement. Replace only the grommet.
The above vehicles may include an on-wheel tire pressure monitoring module that is an integral part of the tire valve stem. This system utilizes a replaceable grommet at the wheel air valve opening. If this grommet becomes damaged or unserviceable, order GM P/N 25715243 for a replacement. DO NOT replace the wheel mounted Tire Pressure Monitoring Module.
Part Number: 25715243
Description: Grommet, Tire Valve
Article ID: 376
Created: July 21, 2014
Last Updated: July 21, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-bulletin-info-tire-pressure-monitoring-system-tpms-grommet-seal-availability-376.html
