From GM TechLink, February 2004:
Two new style fuel line quick connects are in use.
The TI Group Global Quick Connector is used on C/K trucks, S/T trucks, Malibu Sedan, Cadillac XLR and the 2004.5 and 2005 Chevrolet Corvette.
The Legris QC is used on Aztek, Rendezvous, Venture, Montana and Silhouette.
Release
Both Types -- To release the quick connect, push on the retainer using hand pressure only. Do not attempt to remove it.
A - TI type
B - Legris type
Do not use sharp or pointed objects to put pressure on the connector retainer. Using a tool may fracture the retainer, making it less effective at keeping the connector assembled. Also, attempts to remove the retainer with the line inserted will result in retainer breakage.
TIP: If the connector does not release with hand pressure, thoroughly clean it and blow out grit and dirt with compressed air.
Repair
TI Group Global -- If the retainer is broken, it is not necessary to replace the entire fuel line and attached component to repair it. Three sizes of replacement retainers are available.
5/16 po
21992748
3/8 po
22717568
5/8 p0
21992746
Legris -- Replacement parts are not available for the retainer.
- Thanks to Dave MacGillis
Article ID: 387
Created: July 21, 2014
Last Updated: July 21, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2004-2005-corvette-gm-techlink-fuel-line-quick-connectors-387.html
