Subject: Whistle Noise From Intake Manifold/Throttle Body (Replace Intake Manifold)
Number: 02-06-01-021
Models: 2001 Chevrolet Corvette with 5.7L Engine (VINs G, S -- RPOs LS1, LS6)
1999-2002 Chevrolet and GMC C/K Pickup and Utility Models (Avalanche, Silverado, Sierra, Tahoe, Suburban, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL) with 4.8L, 5.3L or 6.0L Engine (VINs V, T, Z, N, U -- RPOs LR4, LM7, L59, LQ9, LQ4)
Condition:
Some owners may comment on a whistle noise coming from either the intake manifold or the throttle body. The noise is most noticeable between 1100 and 2000 RPM.
Cause:
This condition may be the result of airflow through the intake manifold.
Correction:
Replace the intake manifold with the part listed below. Refer to the Intake Manifold Replacement procedure in the Engine Mechanical - 5.7L sub-section of the Service Manual (SI Document ID #642853).
Parts Information:
Part Number |
Description |
Qty |
88894339 |
Manifold, Intake |
1 |
Warranty Information:
Labor Operation |
Description |
Labor Time |
J0250 |
Manifold, Intake - Replace |
Use Published Labor Time |
Article ID: 390
Created: July 21, 2014
Last Updated: July 21, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-corvette-service-bulletin-whistle-noise-from-intake-manifold-throttle-body-replace-intake-manifold-390.html
