1997 - 2003 Corvette: Service Manual Update: Revised Output Shaft Seal Replacement Procedure
Subject: Revised Output Shaft Seal Replacement Procedure
Number: 03-04-20-002 - (01/31/2003)
Models: 1997-2003 Chevrolet Corvette
This bulletin is being issued to revise the Output Shaft Seal Replacement procedure in the Rear Drive Axle sub-section of the Service Manual to reflect the new special tool, J 46405. Please replace the current information in the Service Manual with the following information. The following information has been updated within SI. If you are using a paper version of this Service Manual, please make a reference to this bulletin on the affected page.
1997 Model Year
Tools Required
J 46405 Output Shaft Seal Installer
Removal Procedure
- Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
- Remove the appropriate rear tire and wheel assembly. Refer to Wheel Removal in Tires and Wheels.
- Remove the appropriate drive axle. Refer to Drive Axle Replacement in Drive Axle
Important Take care not to damage any sealing surfaces when removing the differential output shaft seal.
- Remove the differential output shaft seal.
Installation Procedure
- Using the J 46405, install the differential output shaft seal.
- Install the drive axle. Refer to Drive Axle Replacement in Drive Axle.
- Install the rear tire and wheel assembly. Refer to Wheel Removal in Tires and Wheels.
- Lower the vehicle.
1998-2003 Model Year
Tools Required
Removal Procedure
- Remove the appropriate rear tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
- Remove the appropriate drive shaft. Refer to Wheel Drive Shaft Replacement in Wheel Drive Shafts.
- Install the drive shaft. Refer to Wheel Drive Shaft Replacement in Wheel Drive Shafts.
- Install the rear tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Article ID: 397
Created: July 22, 2014
Last Updated: July 22, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-service-manual-update-revised-output-shaft-seal-replacement-procedure-397.html
