Subject: Intermittent Accessory Drive Rumble Noise During Garage Shift and/or During Parking Lot Maneuvers (Install New Generator with Decoupler Pulley and Accessory Drive Tensioner)
Number: 99-06-04-029A
Models: 1997-2000 Chevrolet Corvette with 5.7 L Engine (VIN G -- RPO LS1) and 4L60-E Automatic Transmission (RPO M30)
This bulletin is being revised to update the correction procedure. Please discard Corporate Bulletin Number 99-06-04-029 (Section 06 -- Engine).
Condition: Some customers may comment on an intermittent accessory drive rumble noise when performing a garage shift and/or during parking lot maneuvers, such as turning the steering wheel to the lock position. This noise may also occur when turning on the air conditioning at idle conditions.
Cause: Engine idle speed may drop below 600 RPM while performing a garage shift, turning the steering wheel to the lock position, or turning on the air conditioning. This noise may be amplified by a large rate of change in engine RPM. This condition can also be aggravated by different low engine RPM driving conditions.
Correction: A new Generator with Decoupler Pulley and reduced damping Accessory Drive Tensioner was implemented for all Corvettes with automatic transmissions at 2001 SOP (Start Of Production). The generator with decoupler pulley is used only on Corvettes equipped with an automatic transmission. The reduced damping accessory drive tensioner is used on all 2001 Corvettes.
The new decoupler pulley generator and tensioner assembly should be used to service 1997-2000 Corvettes with automatic transmissions that exhibit the idle rumble noise. Refer to the Engine Electrical and Mechanical sub-sections of Engine in the Service Manual for generator and tensioner replacement
Parts Information:
Part Number |
Description |
Qty |
10436674 |
Generator Assembly w/Decoupler Pulley |
1 |
12568181 |
Accessory Drive Tensioner |
1 |
Warranty Information:
Labor Operation |
Description |
Labor Time |
J4100 |
Generator Assembly - Replace |
Use Published Labor Time |
J 0680 |
Tensioner, Accessory Drive - Replace |
Article ID: 399
Created: July 22, 2014
Last Updated: July 22, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-intermittent-accessory-drive-rumble-during-garage-shift-399.html
