Model Year: 2002
Subject: Erratic Fuel Gauge Reading (Reprogram the PCM)
Number: 02-06-04-010
Condition
Some owners may comment about the fuel gauge intermittently indicating an empty reading and then return to the correct fuel level indication.
Cause
This condition may result when fuel blends containing aggressive sulphur compounds react with the fuel sender assembly, which may result in voltage spikes being induced on the fuel level signal to the PCM. Use of another fuel blend may reverse this reaction and return the system to normal operation.
Correction
Reprogram the PCM with the new service calibration which is available in the January 2002, Techline TIS 2000 release. Use the TIS 01/2002 or later data update.
Warranty Information
Labor Operation |
Description |
Labor Time |
J6355 |
Powertrain Controller - Reprogram |
0.4 hr |
Article ID: 406
Created: July 22, 2014
Last Updated: July 22, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-406.html
