Number: 00-08-44-006A
Subject: Power Antenna Not Working Properly or is Completely Inoperative (Replace Antenna O-Ring Assembly/Cap Nut & Clean Mast)
Model Year: 2000 Chevrolet Corvette, 2000 Pontiac Firebird, 2000 Chevrolet and GMC G-Van
This bulletin is being revised to change the labor time. Please discard Corporate Bulletin Number 00-08-44-006 (Section 8 -- Body & Accessories).
Condition
Some customers may comment on the power antenna doing the following:
Cause
The O-ring/cap nut material may not be compatible with the lubricant used on the antenna mast. This incompatibility may cause the O-ring/cap nut to enlarge and place a drag on the antenna mast, restricting its movement.
Correction
Inspect the antenna mast and housing for damage (bent mast or housing). If damaged, perform the normal non-warranty repair. Otherwise, if no damage is present, perform the following repair:
Parts Information
Model |
Part Number |
Description |
Camaro & Firebird |
12369494 |
O-Ring Assembly/Cap Nut |
Corvette |
88896816 |
G-Van |
88897381 |
Article ID: 409
Created: July 22, 2014
Last Updated: July 22, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-power-antenna-not-working-properly-or-is-completely-inoperative-409.html
