Subject: Erratic Fuel Gauge Reading (Reprogram the PCM)
Number: 02-06-04-010A - (06/27/2003)
Models: 1999-2002 Chevrolet Corvette
This bulletin is being revised to add models and update the Correction and Warranty Information. Please discard Corporate Bulletin Number 02-06-04-010 (Section 06- Engine).
Condition:
Some owners may comment about the fuel gauge intermittently indicating an empty reading and then return to the correct fuel level indication.
Cause:
This condition may result when fuel blends containing aggressive sulphur compounds react with the fuel sender assembly, which may result in voltage spikes being induced on the fuel level signal to the PCM. Use of another fuel blend may reverse this reaction and return the system to normal operation.
Correction:
Reprogram the PCM with the new service calibration which is available in the June 2003, Techline® TIS release sent to the dealers on 6/28/03. Use the TIS Version 7 or later data update.
Article ID: 411
Created: July 22, 2014
Last Updated: July 22, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-erratic-fuel-gauge-reading-reprogram-the-pcm-411.html
