Number: 01-06-04-022
Subject: Inaccurate/Erratic Fuel Level Gauge Readings (Install New Sensor, Strainer and/or RH Fuel Sender Assembly)
Model Year: 1997-2000 Chevrolet Corvette
Condition
Some owners may comment about inaccurate/erratic fuel level gauge reading conditions such as those indicated below:
Cause
The conditions indicated above may be the result of one or a combination of more than one of the causes indicated below:
Correction
Inspect the Julian date codes located on the bar code labels attached to the R.H. and L.H. fuel level sender assembly cover plates as shown in the figure. If the R.H. sender date code is less/smaller than "01301", replace the complete assembly with a new fuel sender kit indicated below by model year. If the L.H. sender date code is less/smaller than "32791", replace the existing fuel sender sensor and strainer with those components contained in the applicable sensor and strainer kits shown below by model year.
To insure correct installation, follow the service procedure contained in the applicable Service Manual and the instructions contained in the service kits.
Parts Information
Part Number |
Description |
88896043 |
R.H. Fuel Sender Kit (1997-1999 M.Y.) |
88895126 |
R.H. Fuel Sender Kit (2000 M.Y.) |
88899034 |
Fuel Sensor Kit (1997-2000 M.Y.) |
12458245 |
Fuel Strainer Kit (1997-1999 M.Y.) |
12459862 |
Fuel Strainer Kit (2000 M.Y.) |
Article ID: 420
Created: July 23, 2014
Last Updated: July 23, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2000-corvette-service-bulletin-inaccurate-erratic-fuel-level-gauge-readings-420.html
