Subject: INOPERATIVE REMOTE KEYLESS ENTRY (RKE) SYSTEM AND/OR TIRE PRESSURE MONITOR (TPM) SYSTEM (REPLACE RECEIVER)
Number: 83-90-14
Models: 1997-1998 Chevrolet Corvette
CONDITION:
SOME CUSTOMERS MAY COMMENT THAT THE REMOTE KEYLESS ENTRY (RKE) SYSTEM AND/OR THE TIRE PRESSURE MONITOR (TPM) SYSTEM IS INOPERATIVE IN TEMPERATURES BELOW 18 DEGREES CELSIUS (50 DEGREES FAHRENHEIT).
CAUSE:
SOME REMOTE DOOR/REAR COMPARTMENT RECEIVERS WERE BUILT WITH AN INTERNAL COMPONENT THAT MAY BE SUSCEPTIBLE TO COLD TEMPERATURES.
CORRECTION:
INSTALL NEW REMOTE DOOR/REAR COMPARTMENT RECEIVER, FOLLOWING THE PROCEDURE IN THE SERVICE MANUAL.
PARTS INFORMATION:
Part Number: 10422088
Description: RECEIVER, REMOTE DOOR/REAR COMPARTMENT LOCK
Article ID: 424
Created: July 23, 2014
Last Updated: July 23, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-inoperative-remote-keyless-entry-system-and-or-tire-pressure-monitor-system-424.html
