Number: 00-06-05-002
Subject: Exhaust Boom at 1500 RPM (Install Spacers to Exhaust Hanger)
Model Year: 2000 Chevrolet Corvette
Built from S.O.P. through December, 1999
Condition
Some customers may comment on an exhaust boom heard inside the vehicle at 1500 RPM. Customers may also indicate an exhaust pipe outlet to fascia misalignment.
Correction
Install one 2 mm (.079 in) thick washer on each stud (2 per side), P/N 11505463, between the bumper bar and the muffler hanger, using the following procedure:
Parts Information
Part Number |
Description |
11505463 |
Washer, Flat 2mm |
Article ID: 429
Created: July 23, 2014
Last Updated: July 23, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-corvette-service-bulletin-exhaust-boom-at-1500-rpm-429.html
