Subject: Information on Customer Questions About Valve Guide Wear
Models: 2006-2013 Chevrolet Corvette 427, Corvette Z06 Equipped with 7.0L V8 Engine (RPO LS7)
Customer Concern
Some owners of Corvettes equipped with the LS7 7.0L V8 engine may ask your dealership to check their vehicle for valve guide wear because of information that has been distributed on the internet, primarily at Corvette enthusiast sites. Due to these postings, some customers that have not had an issue may ask to have their vehicle checked. If a customer presents their vehicle and requests the valve guides be checked, the following information may be helpful to you and alleviate any concern for your customer.
Valve Guide Wear / Noise Concerns
To address any concern the customer may have, listen to the customer’s request and ask the following questions to differentiate if the customer has experienced a correctable engine concern or has anxiety over information they may have read.
Important: It is important to investigate all concerns and relay good factual information to your customer. If a customer indicates a concern about valve guide wear, it is possible they may have a valid unrelated engine issue, and do not know how to express the actual concern.
Once the information is collected, and the nature of the customers concerns are known, here are some guidelines for appropriate actions:
Aftermarket Equipment and Valve Guide Wear
The use of performance engine modifications has been found to accelerate valve guide wear. Replacement aftermarket mechanical parts, or software calibrations, may adversely affect the wear of these and other components. Any modification to the engine of GM vehicles voids the powertrain coverage portion of the vehicle warranty. For additional information on GM policies regarding aftermarket equipment and calibrations, please refer to the GM Service Policy & Procedures Manual, article 1.4.14 (Voided Warranties and Branded Titles) and article 1.2.2.12 (Non-GM Parts & Equipment and Original Equipment Alterations), along with the latest versions of Corporate Bulletin numbers 09-00-89-016 and 09-06-04-026 for additional information.
Article ID: 43
Created: July 2, 2014
Last Updated: July 2, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-2013-corvette-z06-service-bulletin-information-on-customer-questions-about-valve-guide-wear-43.html
