Number: 01-07-30-038
Subject: DTC P0757 Set, SES Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris)
Model Year:
1999-2002 Chevrolet Camaro, Corvette
1999-2002 Pontiac Firebird
1999-2002 Chevrolet and GMC C/K Pickup and Utility Models (Silverado, Sierra, Suburban, Tahoe, Yukon, Yukon XL)
1999-2002 Chevrolet and GMC G-Van Models (Express, Savana)
1999-2002 Chevrolet and GMC M/L-Van Models (Astro, Safari)
1999-2002 Chevrolet and GMC S/T Pickup and Utility Models (S-10, Sonoma, Blazer, Jimmy)
2002 Chevrolet and GMC S/T Utility Models (New Style) (TrailBlazer, Envoy)
1999 Cadillac Escalade
1999-2002 Oldsmobile Bravada
Condition
Some customers may comment on any of the following conditions:
Cause
The most likely cause is chips or debris plugging the bleed orifice of the 2-3 shift valve. This will cause the transmission to stay in 2nd gear and return to 1st gear when and/or if the PCM attempts a 3-4 shift.
DTC P0757 code may also be set if the 2-3 shift valve were stuck or hung-up in its bore. Inspect the 2-3 shift valve and the 2-3 shuttle valve for free movement or damage and clean the valves, the bore and the valve body passages.
Correction
The 1-2 and 2-3 shift solenoid valves (also called A and B solenoids) are identical devices that control the movement of the 1-2 and 2-3 shift valves (the 3-4 shift valve is not directly controlled by a shift solenoid).
The solenoids are normally-open (not energized electrically) exhaust valves that work in combination to shift the transmission into four different forward gears. Opening and closing the exhaust valves within the solenoids redirect the transmission fluid, hydraulically moving shift valves and the corresponding shifting of the transmission gears.
The PCM energizes (turns On) or de-energizes (turns Off) each solenoid by either grounding or removing the ground to the solenoid through a quad driver (switch) within the PCM. This allows current flow through the coil winding of the solenoid which causes movement of the internal plunger, blocking or opening an internal orifice.
The 2-3 shift solenoid (SS) valve controls the fluid flow acting on the 2-3 shift valves.
The vehicle speed sensor (VSS) assembly provides vehicle speed information to the PCM. The VSS assembly is a permanent magnet (PM) generator. The PM generator produces a pulsing AC voltage as rotor teeth on the transmission output shaft pass through the sensor’s magnetic field. The AC voltage level and the number of pulses increase as the speed of the vehicle increases. Output voltage varies with speed from a minimum of 0.5 volts at 100 RPM of the transmission output shaft to more than 100 volts at 8000 RPM of the transmission output shaft. The PCM uses the pulsing voltage to determine vehicle speed. The PCM uses the vehicle speed signal to determine shift timing and TCC scheduling.
Estimated gear ratio is calculated by the PCM, using the estimated torque converter turbine speed (estimated turbine speed is calculated from engine speed and engine torque) divided by the transmission output speed (VSS). The estimated gear ratio is displayed on the Tech 2 as a range of 0.00:1 to 8.00:1.
Gear |
1-2 Shift Solenoid |
2-3 Shift Solenoid |
Gear Ratio |
1 |
ON |
ON |
3.059:1 |
2 |
OFF |
ON |
1.625:1 |
3 |
OFF |
OFF |
1.00:1 |
4 |
ON |
OFF |
.696:1 |
P0757 will be set, stored within the PCM, when the PCM has detected an incorrect shift pattern when both of the following occur:
AND
The PCM then takes the following actions:
Step |
Action |
Value(s) |
Yes |
No |
1 |
Did you perform the Powertrain Diagnostic System Check? |
Go to Step 2 |
Go to Diagnostic System Check - Engine Controls in Engine Controls |
2 |
Did you detect a 1-2-2-1 shift pattern? |
Go to Step 3 |
Go to Diagnostic Aids |
3 |
Did you find and correct the condition? |
Go to step 4 |
4 |
Perform the following procedure in order to verify the repair:
Has the test run and passed? |
System OK |
Go to Step 1 |
Article ID: 432
Created: July 23, 2014
Last Updated: July 23, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1999-2002-corvette-service-bulletin-dtc-p0757-set-ses-lamp-illuminated-poor-performance-of-transmission-transmission-slipping-432.html
