1990 - 2003 Corvette: Service Bulletin: Info - Diagnosis of Cracked or Broken Transmission Case
Number: 02-07-30-024
Subject: Info - Diagnosis of Cracked or Broken Transmission Case
Model Year:
1990-1993 Buick Roadmaster, Estate Wagon
1990-1996 Cadillac Fleetwood
1990-1996 Chevrolet Caprice
1990-2002 Chevrolet Camaro
1990-2003 Chevrolet Corvette
1995-1996 Chevrolet Impala
2000-2003 Chevrolet Impala
1990-1992 Oldsmobile Custom Cruiser Wagon
1990-2002 Pontiac Firebird
1990-2003 Chevrolet and GMC C/K Models (Silverado, Sierra, Avalanche, Suburban, Tahoe, Yukon, Yukon XL)
1990-2003 Chevrolet and GMC G-Van Models (Express, Savana)
1990-2003 Chevrolet and GMC M/L-Van Models (Astro, Safari)
1990-2003 Chevrolet and GMC S/T Models (S-10, Sonoma, Jimmy, Blazer, TrailBlazer)
2000-2003 Cadillac Escalade
1991-1994 Oldsmobile Bravada
1996-2002 Oldsmobile Bravada
with 4L60/4L60E/4L65E or 4L80E/4L85E or Allison® Series 1000 Automatic Transmission
Diagnosing the cause of a cracked or broken transmission case requires additional diagnosis and repair or a repeat failure will occur.
A cracked or broken transmission case is most often the result of abnormal external torsional forces acting on the transmission case. If none of the conditions listed below are apparent, an internal transmission component inspection may be required. Repairs of this type may be the result of external damage or abuse for which General Motors is not responsible. They are not the result of defects in materials or workmanship. If in doubt, contact your General Motors Service Representative.
The following items should be considered:
In some cases, the customer may not comment about a vibration but it is important to test drive the vehicle while using the electronic vibration analysis tool in an attempt to locate the cause of the torsional vibration. Refer to the Vibration Diagnosis and Correction sub-section of the appropriate Service Manual for more details on diagnosing and correcting vibrations.
Article ID: 439
Created: July 23, 2014
Last Updated: July 23, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html
